04-09-2013, 06:35 PM | #1 |
What fuel tank to use
I've got a 58 Apache mounted on an 84 C10 frame. I want to get the gas tank out of the cab but I'm not sure what to get. I don't know the differences between the 58 and 84 frames so I'm not sure if one of the tank kits that mount in the rear frame would work with my 84 frame. I can do some fab work if needed but if there's a bolt in kit I would consider it based on price. What's the best way to go here?
58 Fleetside 71 Cheyenne |
04-09-2013, 07:02 PM | #2 |
Re: What fuel tank to use
I have a 78 blazer frame on mine, and useing a 15 gallon fuel cell.
only fab work i had to do was the straps to hang the fuell cell, and all thread. I used 1" flat metal and shaped it to the fuel cell. used the spare tire mount to attach it. Im pretty sure it might be the same for your set up, or why not go with with the stock locatinon for the C10.
Memo S. Retired US Marine Family Man |
04-09-2013, 08:32 PM | #3 |
I just did a search here and found a couple of ways to go.
LMC has a rear mount tank set up. And the Suburban has a rear tank that will work also. See Pic's. Another option could be a Mustang Tank.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
04-10-2013, 12:36 PM | #4 | |
04-10-2013, 01:52 PM | #5 |
One thing I don't understand is, is why do people switch Frames ?
1971 GMC Sierra 1959 GMC 100 |
04-10-2013, 03:01 PM | #6 |
do you still have the stock tank, try useing it to mock up or see where you can best use it, save money for other parts as well.
post pics if you have them
04-10-2013, 03:48 PM | #7 |
GR, is that YOUR '57 Jimmy in the last photo?
The thing I'd not be happy with about a top flange bolted tank would be the MAJOR hassle if you ever needed to lower it!! I think Orrie has commented on that problem before. Posted via Mobile Device |
04-10-2013, 03:52 PM | #8 |
This issue: getting the tank out of the cab, along with:
3 point seat belts and An emergency/parking brake (especially since I still have the single pot master cylinder) ...are all on my mind now as I get mine to the point of being able to just jump in and run errands with it. All are safety issues and I don't want to compromise on safety. Remember, "Make it stop, make it go, then make it COOL!" is the motto. |
04-10-2013, 06:56 PM | #9 | |
I used a NoLimit tank, its mounted to the bottom flange.
04-10-2013, 07:35 PM | #10 |
Is that it bolted in? Looks like it hangs down no lower than the hitch, is that accurate?
I've read (somewhere! Lol) that U-Haul has a receiver hitch that's a direct bolt on for our trucks. I even have the model no. somewhere. Is that what yours is? Posted via Mobile Device |
04-10-2013, 07:38 PM | #11 |
I wonder how to install one of them
04-10-2013, 07:50 PM | #12 | |
The lowest point on my L.W.B. '57 at 5' behind the rear axle center line with the rear air suspension deflated is 5" between the receiver and the shop floor.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 04-10-2013 at 07:57 PM. |
04-10-2013, 07:54 PM | #13 |
That's SWEET! I like the way the hitch fit's, nice addition to your truck.
04-10-2013, 08:37 PM | #14 |
Looks great man
04-10-2013, 09:24 PM | #15 | |
Unfortunately the C10 tank was never used, previous owner left the 58 tank in the cab. I do have access to a C10, I'll try to get an idea if it's doable.
04-10-2013, 11:10 PM | #16 |
Can you not update the Suspension, and not the Frame ?
