| View Poll Results: What direction to head next | |||
| Idle Circut |
2 | 20.00% |
| Vacuum Leak |
1 | 10.00% |
| Ignition/Timing |
3 | 30.00% |
| Junk the Eddy |
4 | 40.00% |
| Multiple Choice Poll. Voters: 10. You may not vote on this poll | |||
I am new to the forums and this is my first post, so bear with me and guide me where I need to go. I have a 1986 C10 with a modified 305, from what I know it has
601 heads I Think .204/.214-.420/.443 cam 112 lobe SA performer intake stock Edelbrock 1406 electric choke. I have searched all over with no luck. The issue I am having is today out of the blue, I feel like I am getting a miss on one cylinder only at idle. All plugs are firing,tested for vacuum leaks, Nada! Here is the kicker I turn the the idle mixture screw on the Right, engine stalls(Normal)... Turn the one on the Left, and the idle increases when turned clockwise, decreases and stalls counter clockwise. ![]() I am leaning towards a blocked idle mixture bleed tube/circuit (as it is the next cheapest thing to check but need shop air to blast it clean) Thanks, Look forward to many more head scratching moments with yall.... |
| Bookmarks |
