Old 04-09-2013, 09:28 PM   #1
MikeS.
MikeS.'s Avatar
Clr
What are the steps for using CLR on the rust? Use it full strength or dilute it? Which Scotch Brite pads?
My 66 is a great candidate for this from what I've seen on here.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 04-09-2013, 10:01 PM   #2
Justin36
Justin36's Avatar
Re: Clr
Hey mike I just did this with great results. I used 3 parts CLR to 1 part warm water and green scotchbrite pad and just hit the spots that I wanted to do, once you get started you'll see what you need/ or how much you want to do! Here is a couple pics
Justin
Justin36 is offline   Reply With Quote
Old 04-09-2013, 10:02 PM   #3
Justin36
Justin36's Avatar
Re: Clr
The shine it has in the pics is because it's still wet too btw
Justin
Old 04-10-2013, 01:39 AM   #4
MikeS.
MikeS.'s Avatar
Re: Clr
Thanks Justin!
Past Master
