Old 04-09-2013, 09:59 PM   #1
62 bigwindow
62 bigwindow's Avatar
Question about "air" gauge
I thought I would ask since I know you guys could answer this.
I recently bought a 65 big window shortbed fleet side and the gauge cluster has
the factory tach on right side and "Air" gauge on the left
Curious what you guys know about the air gauge and how it works
62 bigwindow is offline   Reply With Quote
Old 04-09-2013, 10:02 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Question about "air" gauge
More than likely somebody put that gauge in there from a big truck. Those were used to monitor air brakes on the bigger trucks and now guys are installing them to monitor their air bag system for the suspension. They are quite sought after.
Old 04-09-2013, 10:11 PM   #3
62 bigwindow
the gauge looks factory almost like maybe it reads air tempature
the guy I bought it from was in his 70s and said he bought the truck in 1971
when he came home from over seas( I am guessing vietnam) and his father in law bought it new I have the original owners manual. That why I think it is original
Old 04-09-2013, 11:07 PM   #4
Snowbound
Snowbound's Avatar
I just pulled one out of a 5 ton truck. It is air pressure and the tubing to the back of the gauge tee'd off to the air horns on top of the cab.
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 04-10-2013, 05:56 AM   #5
62 bigwindow
makes no sense to me.. this is a c10 so no air horn or air brakes
Old 04-10-2013, 08:24 AM   #6
1963c-10
1963c-10's Avatar
At some point he converted from warning lights to factory guages. Same thing alot of us are doing now.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-11-2013, 09:18 AM   #7
kieth
kieth's Avatar
Where is the picture, we could tell a lot more from that. Could it be a vacuum gauge ?
kieth is offline   Reply With Quote
Old 04-11-2013, 09:25 AM   #8
theastronaut
theastronaut's Avatar
Here are pics of my air gauge cluster. It came out of a larger C60-C80 truck with air brakes, I'll be hooking to the air tank since I'll be running bags. They only came on large trucks with air brakes so someone has swapped yours out in the past, not an uncommon upgrade to get a tach but most guys use a vacuum gauge instead of an air gauge.
theastronaut is offline   Reply With Quote
