Old 04-09-2013, 10:13 PM   #1
79bonanza
AN fittings to stock sending unit.
How are you guys attaching your fuel line to your fuel pump sending unit?
Is it possible to cut and reflare it to a 37 degree flare and use a line collar and nut.
I'm trying to make it look good and be good so I'm trying to not just clamp it to the tube.
Any thing would be useful
79bonanza is offline   Reply With Quote
Old 04-10-2013, 02:18 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: AN fittings to stock sending unit.
I found a 3/8 compression fitting to -6 AN fitting on eBay...
I may just stick with my original plan of using a parts counter nylon fuel line fix and a dorman compression fitting....
Check my build thread for some more details...
Rich
1972 K5 Blazer CST Click HERE
Old 04-10-2013, 08:30 AM   #3
mej005
Here is a thread I started the end of last year:
http://67-72chevytrucks.com/vboard/s...t=sending+unit
I used the compression adapters and so far have not had any leaks or blowouts, there are links to them in the first post. Just don't overtighten them because you risk cracking the ferrel.
mej005 is offline   Reply With Quote
Old 04-10-2013, 10:28 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
Compression fittings with -6 ends work awesome. I've used them a lot.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
