Drive on ramps
I like using drive on ramps for oil changes and other stuff, and I was wondering if there is any of the ramps that are designed to give you a bit more height than normal? My truck is lowered, and would like to have some that would raise it a bit more.
Thanks guys. |
Re: Drive on ramps
Check out race ramps, They have ramps made from a lightweight High density foam. I believe they can custom make things but i could be wrong. One of their best features are the ramps you drive onto then pull the ramp part out of the way leaving only a "pedestal" under the wheel. Makes it much easier to roll around under there with the creeper.
http://www.raceramps.com/ |
Re: Drive on ramps
I would drive up ramps then jack high enough to put heavy duty stands and good chocks and apply e-brake and leave jack under vehicle for good measure.
#4 | |
Parts and more parts
Re: Drive on ramps
Frank |
Re: Drive on ramps
Look for a used kwik lift
Fuzzy |
78K & 79C Jimmys
Re: Drive on ramps
prob to high,and need space, but you could look for a car dealer display ramp,up about 4 feet?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: Drive on ramps
Here is a pic of a kwiklift
Fuzzy |
78K & 79C Jimmys
Re: Drive on ramps
nice,had not seen those,I'd roll on that , accessories included? lol
Re: Drive on ramps
Thanks guys for the help. Those kwiklifts look cool.
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: Drive on ramps
Re: Drive on ramps
I would think that kwik lift would be ideal for my limited 8' ceiling,wonder what setup u would have to have to pull a trans??Still would like to have one
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: Drive on ramps
I remember seeing that exact pic of that exact car on TGO! IIRC, he was selling the wheels.
All those manufactured ones are not cheap. I made my own out of Pressure Treated 2"x12" lumber for my low '87 GTA. Cut the tips at a 45degree angle, wood screws to hold them together and voila! Not exactly light, but not TOO heavy to use either. And it isn't like you really need to move them around that much/that far. My homemade lumber ramps
2001 ![]() Last edited by TexasSteve; 04-15-2013 at 06:54 PM. |
