Old 04-10-2013, 10:32 AM   #1
allons
Rear end width
I've got a '72 C10 1/2T with a 12 bolt non-posi rear end with 3.73 gears. Is there someplace that I can find the exact rear end width dimension from the wheel mounting face on the drum to the opposite wheel mounting face? I need an accurate reference and I haven't been able to find that dimension. Any help?
allons is offline   Reply With Quote
Old 04-10-2013, 11:24 PM   #2
Robznob11
Robznob11's Avatar
Re: Rear end width
not sure on mounting face to face. but I can tell you most people measure from backing plate to backing plate. the 70 and earlier rears are like 1/2" narrower. if you call moser they could probably tell you because I ordered my axles from them and they already had the specs!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-11-2013, 04:19 AM   #3
wraprail
wraprail's Avatar
Re: Rear end width
Maybe try a straight edge and a tape measure?
Thats what I would do.
Almost forgot, remove the wheels first.
wraprail is offline   Reply With Quote
Old 04-12-2013, 08:21 AM   #4
Hertzdaddy
Re: Rear end width
Jack up the rear, remove wheels, drop a weighted string from each WMS to the floor, mark and measure.
Hertzdaddy is offline   Reply With Quote
Old 04-12-2013, 10:00 AM   #5
oldman3
oldman3's Avatar
Re: Rear end width
Both of these are the best way to know exactly what you have. I did a search on the forum and this is what it showed:
67 & 68 are 60"
69 & 70 are 62"
71 to 87 are 63.5"
88 to 98 are 65"
These are approximate but should help after checking yours....Jim
oldman3 is offline   Reply With Quote
Old 04-12-2013, 12:00 PM   #6
allons
Re: Rear end width
Thanks everyone, I'll be pulling everything out and doing the measurements this w'end. Thanks again
