Switching to gauge cluster
I am switching out my gauge cluster from the warning light cluster to the actual gauges. I have a wiring harness on order. Looking to find the correct oil and temp sending units. Can I pull from a newer 350 I have? Would they still read correct?
Re: Switching to gauge cluster
Your oil pressure uses a presure switch, they are the same I believe but will see what the others say, you will need the correct temp sender, you can get them thru Truck and Car Shop...page 93 in the online catalog.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Thx. haven't ever been to that site. It is awesome.
Proud Americano
![]() Join Date: May 2008
uhmmm....the oil gauge is mechanical.it takes a line from the engine to the oil gauge.
the temp senssor can be had at a napa or autozone. hope this helps
Tattooed Cuban Trailer Trash. putting the cart before the horse since 1964. |
#5 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I had no luck getting my temp gauge to read accurately with parts house sending units. Based on a tip I got on the Team Chevelle website, I got sending units from these guys..
http://www.lectriclimited.com/ and the factory temp gauges now work perfectly in both my 69 Chevelle and my 64 C10. |
#7 | |
Make sure not to use teflon tape on the temp sending unit. I got mine from classic parts 3 years ago...no issues.
