04-10-2013, 06:51 PM | #1 |
Clicking when I turn wheel
I've begun to notice a clicking noise when I turn the wheel on my truck. It doesn't seem to be coming from the power steering pump, it seems to be on the driver's side, it does it when you turn right or left but not on the return, and it doesn't always occur in the same position. I put my hand on the steering box but could not feel a corresponding ping there when the noise occured. I looked at the suspension too and didn't see anything obvious. Any ideas?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
04-10-2013, 08:54 PM | #2 |
Re: Clicking when I turn wheel
Horn relay maybe? Is the sound coming from the steering column?
04-10-2013, 09:04 PM | #3 |
Could be a wheel bearing
Posted via Mobile Device |
04-10-2013, 10:13 PM | #4 |
Seems to. I'll unplug the horn and see if it goes away
04-10-2013, 10:30 PM | #5 |
Or turn signal switch interference?
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
04-10-2013, 10:33 PM | #6 |
Sounds like your horn button could be grounding and it's setting the relay off.
71 K20 64 GMC mud truck |
