Old 04-10-2013, 10:45 PM   #1
Codez67Chevy
Codez67Chevy's Avatar
Info. Please
Ok here are my questions. I'm getting thrown around by my truck here.
1. Vin says its a 1/2 ton, and it has 6 lug axles. So then did all the 1/2 tons come with 5 or 6 lug?
2. It has C20 badges on it, given info from the vin I'm sure its a C10. Its 2WD and coil suspension so were leafs an option with these trucks back then?
3. I keep thinkin its a C20 cuz its got a 292 in it and I thought that GM put the 292's in the C20's and up?
I'm sure I'm wrong about some things. Just need some info cuz I'm gonna start putting some money in this thing so I wanna buy the right stuff.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 04-10-2013, 11:11 PM   #2
buckskins4ever
buckskins4ever's Avatar
Re: Info. Please
1. Half tons were 6 lug up until 71, when they started doing front disc brakes.
2. leafs were an option on our trucks. From what I have found coils were standard
Cant help with the 292 issue. but does it have the appearance or you have knowledge that the front clip or cab have been changed out?
buckskins4ever is offline   Reply With Quote
Old 04-10-2013, 11:13 PM   #3
Lattimer
Lattimer's Avatar
Re: Info. Please
From what I know, the 292 was available in pretty much any level truck. C-20 would be an 8 lug wheel.
Leaves were an option on C-10's.
Sounds to me like somebody swapped badges, or possibly fenders on your truck.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-10-2013, 11:38 PM   #4
Codez67Chevy
Re: Info. Please
Yea I was kinda thinkin that the fenders could have been swapped. And the cab is a 67 small window. So more or less I'm pretty sure its a C10. Gonna have to change those baddges.
Members I've met...
Mister-B
Old 04-11-2013, 03:27 AM   #5
SS Tim
SS Tim's Avatar
Re: Info. Please
This is easy.
Coils were std on both C10 and C20.
If it is an uncut swb frame it is a C10.
If it was cut then measure the frame.
C10 127 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus
C20 127 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
292 engines were optional for a C10 in 67.
The engine codes were the same for all the variations and did not differentiate series (C10-30).
SS Tim is offline   Reply With Quote
