Old 06-20-2003, 10:10 PM   #1
Purs
Got Big Block?
Purs's Avatar
installing a torque converter
Somebody help! How much transmission fluid do I put in the converter before I put it on? Are there any tricks to getting it right? Does it bottom out against the tranny or what? Thanks for the help. It's my first time with this if you couldn't tell.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 06-20-2003, 10:20 PM   #2
racedvl
racedvl's Avatar
If I can rembember correctlly, I put at least a quart in mine, then pushed, and spun clockwise, till it was all the way in.
racedvl is offline   Reply With Quote
Old 06-20-2003, 10:32 PM   #3
junkyardjohn
junkyardjohn's Avatar
POUR IN ABOUT 3 OR 4 QUARTS OF TRANNY FLUID. FILL IT RIGHT UP, & DEPENDING HOW EMTY IT IS WILL DEPEND ON HOW MUCH IT HOLDS. PUT A NEW PUMP SEAL IN THE TRANNY (ABOUT $3). PUT THE TORQUE CONV. ON THE SHAFT, & ROTATE IT AS YOU PUSH GENTLY BUT FIRMLY ON IT. YOU WILL FEEL IT CLICK,& MOVE REARWORD ABOUT 1/4" OR 3/8" THREE TIMES. BOLT UP THE TRANNY TO THE MOTOR. YOU SHOULD HAVE ABOUT 3/8" CLEARANCE BETWEEN THE T/C & THE FLEXPLATE. THE TORQUE CONVERTER SHOULD ROTATE FREELY BEFORE YOU BOLT IT TO THE FLEXPLATE, OR ELSE YOU DON'T HAVE IT INDEXED IN PROPERLY. IT'S A PIECE OF CAKE, ONCE YOU'VE DONE IT A FEW TIMES. GOOD LUCK JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-20-2003, 10:37 PM   #4
Gordo
Smile
1 qt does it, and work/spin it back until you can't get your fingers between the TQ and the bellhousing. Sometimes it drops back easy and sometimes it don't.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-20-2003, 10:37 PM   #5
Purs
Got Big Block?
Purs's Avatar
many thanks for all the responses. Thanks to you guys I'm learning.
Old 06-20-2003, 11:05 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 3 tranny shops I deal with at work all say one quart is fine. One even says NEVER put in any more than one...but no one has been able to say why you don't want to do that.
Old 06-20-2003, 11:47 PM   #7
Piston
Piston's Avatar
When we install one it gets 1qt for basic lubrication only. Then pour 4qts in through the dipstick tube, start the engine briefly then add another 3qts. Once you have 8 qts in it, you know it won't run dry while your checking/adding the fluid. DON'T try and pour it all in at once, you'll find most of it coming out the vent hole lol.
Andy I believe most will say 1qt for lubrication reasons, then they would prefer the rest be poured into the pan so the filter will have a chance to remove anything before it hits the pump/valvebody.
Piston is offline   Reply With Quote
