04-11-2013, 07:28 AM | #1 |
latch spring
on a 72 does it have a hood spring that pops the hood up when you pull the latch,if it does is where is it,on the latch or on the hood latch bolt,thanks
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
04-11-2013, 07:33 AM | #2 |
Cluster King
Re: latch spring
No spring on the latch. It pops because of tension on the hood hinge springs.
There is a spring that helps return the latch to the latched position after it is pulled. |
04-11-2013, 11:53 AM | #3 |
20' Daredevil (Ret)
Re: latch spring
^ Yes. If your hood doesn't pop up an inch or so when you release the latch, try some light oil (WD-40 will work) on all the hood hinge pivot points.
04-12-2013, 06:28 PM | #4 |
Re: latch spring
thank you
04-12-2013, 06:29 PM | #5 |
Re: latch spring
thank you
