Old 04-11-2013, 02:50 PM   #1
Mick65
Issue turning off ignition
When I turn off my 65 C10 it continues to run for a few more seconds before turning off. It almost acts like when a diesel turns off. Does anybody know what could cause this?
Mick65 is offline   Reply With Quote
Old 04-11-2013, 03:04 PM   #2
DesertCat
DesertCat's Avatar
Re: Issue turning off ignition
Need a lot more info about the problem, history of how it runs, history of any recent changes, what is stock and what is custom.....
But here's a quick stab in the dark - Do you have an alternator on it? Improperly wired alternators can feed back to the ignition circuit.
Timing?
carb clean, properly adjusted?
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 04-11-2013, 03:14 PM   #3
kerber63
kerber63's Avatar
Do you have an electric fan? When I originally installed my dual setup they would keep the motor running for a few seconds after the ignition shut off. Because they would be turning when the power shut off, they acted as a weak alternator and fed the engine with power until they stopped spinning. A cheap diode from RadioShack fixed the problem.
kerber63 is offline   Reply With Quote
Old 04-11-2013, 03:22 PM   #4
Mick65
The timing is definitely off and needs to be sorted. I do have an electric fan. Thanks guys. I'll take a look at these
Old 04-11-2013, 03:24 PM   #5
Sharps40
Couple common possibilities.
Carb out of adjustment/something not functioning in the idle circuit of the carb.
Fouled spark plugs, valves or pistons causeing a hot spot.
Timeing off.
Feedback as mentioned from electric fans, hei, alternator or other devices plugged into the wrong spot.
My vote is for carb issues or timeing.
Sharps40 is offline   Reply With Quote
Old 04-11-2013, 03:26 PM   #6
shawno72
C/10 junkie
shawno72's Avatar
Timing to advanced or retarded?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-11-2013, 03:51 PM   #7
ky-donzi
x2 on the fans had it happen on a truck i had, unhook them and try it... If i remember correctly it depends on where they get there power from if they can back feed the ing circuit. Seems like the problem was traced to hooking the fans directly to the fuse panel... Seems like the fix we used was a relay that killed with the key switch.
ky-donzi is offline   Reply With Quote
Old 04-11-2013, 04:22 PM   #8
forestb
forestb's Avatar
Mine was doing the same thing a while back ago. If it is not the timing check for a vacuum leak.
forestb is offline   Reply With Quote
Old 04-11-2013, 07:56 PM   #9
tincan1966
tincan1966's Avatar
In order to help fix- have to know what it is doing. Is it dieseling or is it not shutting off?
If it's dieseling, then check timing, idle speed and for a vacuum leak as mentioned. If it just doesn't shut off(keeps running normally) then you most likely have a feedback of the alternator, as posted earlier.
tincan1966 is offline   Reply With Quote
Old 04-12-2013, 07:59 PM   #10
Mick65
I took it to a shop today to get it timed and the mechanic (whos a genius) and he said that it was my electric fan giving feedback. I'm going to get this fixed on monday. Thanks for everybodys help
Old 04-12-2013, 08:14 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Sounds like an easy fix!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-13-2013, 06:00 PM   #12
ChrisDollins
ChrisDollins's Avatar
Just wondering if this fixed your issue or not. My 250 is doing the same thing, just recently got worse after installing pdb/ps. But it also has been hotter outside too. Turn the key off and it sputters for about 5 seconds or more. No electric fan, engine runs and starts great. Factory single barrel carb rebuilt about 4 years ago. Don't know what temp the engine is running just yet, only have the lights right now. Thanks for any help.
Chris
ChrisDollins is offline   Reply With Quote
Old 06-13-2013, 06:13 PM   #13
1restorick
1restorick's Avatar
Trying removing the Generator light bulb. My truck did this after installing an MSD ignition. Only it would never shut off period and the generator lamp was lit with the key in the off position.A diode installed in this lamp circuit solved the problem. Good luck.
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 06-13-2013, 06:18 PM   #14
ChrisDollins
Oh ok. Wonder if the msd had anything to do with it? Mine still has points. It definitely isn't "running" just hitting a couple of times and sounds like a crappy movie car fabricated sound lol. Embarrassing...
Chris
Old 06-13-2013, 06:49 PM   #15
1restorick
1restorick's Avatar
Mine had everything to do with the MSD. They even give you the diode with the MSD box. What is interesting is that I have installed several MDS ignitions over the years in many older cars and my truck was the first vehicle that needed the diode to stop the back feed.
RED RUMBLE
Owned since 1984
Old 06-13-2013, 08:13 PM   #16
ChrisDollins
Ok, starting to think its temperature related. Because we just took it around the yard (little guy loves riding in the truck) and it shut off perfectly.
Chris
Last edited by ChrisDollins; 06-13-2013 at 08:21 PM. Reason: auto correct phone...
Old 06-13-2013, 09:27 PM   #17
hotrodder
Had the same problem it was the electric fan feeding back for a few seconds.
hotrodder is offline   Reply With Quote
