Old 06-21-2003, 01:12 AM   #1
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
Towing with a C Notch?
I am either going to have to c notch my 75 Jimmy or raise it back up a little. I did the flip on the rear and ride is terrible at times. My main concern though is whether you guys think I would still be able to pull a car hauler once I go with a c notch? The Jimmy sits quite low now although not as low as a bunch of your trucks. I just do not know if I could feel safe pulling a loaded car hauler knowing I had done some framework such as a c notch. Anyone here who has already proven this can be done?
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 06-21-2003, 08:59 AM   #2
BIGG BELLY
good parts and good craftsmanship and you should have no problem--i did a bolt-on notch(belltech) and also welded it in place on a 1 ton truck that later had a 5th wheel installed and never had any problems
55 big window long bed
69 olds 98
check out my pics
photo albums
BIGG BELLY is offline   Reply With Quote
Old 06-21-2003, 11:57 AM   #3
454ss_2
454ss_2's Avatar
Get your self a set of airlift helper bags, they are great for towing with a lowered truck.
90 454ss
92 454ss
00 Silverado
08 Avalanche LTZ
454ss_2 is offline   Reply With Quote
Old 06-21-2003, 12:05 PM   #4
ItsNotABlazer
I have a set of those but without a c notch I think that is the main place my poor ride quality is coming from. Will talk to a guy today about making a c notch. I am thinking of seeing about boxing the rear part of the frame also.Just for a little extra strentgh.
Brad
2000 BMW 740iL
Old 06-21-2003, 01:13 PM   #5
SCOTI
SCOTI's Avatar
I agree w/BB on this one. A bolt in 'c' section is fine for just driving, but if your going to do some towing, welding it in is good insurance.
I bolted mine in @ first on my 68 & then when I got my trailer I went ahead & welded everything up for 'piece of mind'. No problems so far (2yrs later).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-21-2003, 07:52 PM   #6
ItsNotABlazer
SCOTI how much is your 68 lowered and how big of a trailer do you pull with it?
Brad
2000 BMW 740iL
Old 06-21-2003, 09:50 PM   #7
SCOTI
SCOTI's Avatar
It's about a 5/7. I used WC 2.5" drop spindles & 1 coil cut off the original, slightly sagging, front springs & have 2600# air bags mounted in the stock coil location + 1.5" blocks & adj panhard bar out back.
I pull an open 18ft steel floored car hauler/trailer. Right @ this moment it has a 67/9 GMC swb frame w/cab sitting on it. It typically rides w/the top of the axle (housing) about .5" into the c-section & my bed floor has the missing wood to prove it . With nothing behind me, I run around w/about 30psi in the bags & w/the trailer, I bump it up to about 70psi to compensate for the xtra weight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
