04-11-2013, 10:10 PM | #1 |
Steering Column help
Im trying to reinstall my non-tilt steering column in my 72 K20. I cant figure out how to reinstall my shift linkage so that it works properly and reinstall my supports in the cab. I have a couple pictures and any help would be great. Thanks
My K20 build http://67-72chevytrucks.com/vboard/s...d.php?t=538539 |
04-12-2013, 09:10 AM | #2 |
2WD Jimmy
Re: Steering Column help
You need to buy a factory assembly manual. When you get in these spots it will bail you out (ask me how I know).
04-12-2013, 09:17 AM | #3 | |
sam |
04-12-2013, 07:40 PM | #4 |
You are missing hardware on the end of the column that holds the bearing housing and shift tube support in place. Here is the only picture that I have of a column and it is missing the bearing and shaft.
I can send you a pdf schematic of the column if you like. It is too big to post and if I resize it the details go away. Send a PM with your e-mail address to me if you want the schematic. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 04-12-2013 at 07:41 PM. Reason: spelling |
