View Poll Results: What type of pump do you prefer for your carb'd performance set up? | |||
Mechanical? | 12 | 70.59% | |
Electric? | 5 | 29.41% | |
Other? | 0 | 0% | |
Voters: 17. You may not vote on this poll |
04-12-2013, 12:29 AM | #1 |
Fuel pump preferences?
I'm currently running an electric fuel pump because that's the way the truck was set up when I bought it. I'm curious as to y'alls thoughts on electric vs. mechanical.
1982 GMC C1500 4x4 w/ 305 and sm465. 2002 Kawasaki Ninja 250. 2007 Dodge Nitro. |
04-12-2013, 01:33 AM | #2 |
Re: Fuel pump preferences?
They are just better for the average vehicle. Even a cheap parts store replacement will keep up with a decent small block easy enough. Plus you don't have the other associated problems as with a electric one. Plus cheap, and electric pump don't work to well together.
Summit even has 2 different mechanical pumps that can run fuel injection 1 for TBI set-ups, and 1 for high pressure set-ups.. Yes it is like $250, but my guess is that it would be quite reliable, and clean looking. |
04-12-2013, 06:23 AM | #3 |
Watch out for your cornhole !
Mechanical pumps are much cheaper and you can get a replacement if needed 7 days a week at any parts store in America.
They almost always last longer too. Posted via Mobile Device |
04-12-2013, 06:37 AM | #4 |
I have run electric Carter fuel pumps for over twenty years with no issues. Never had one go bad either come to think of it. Primes the carb like fuel injection and when it's switched off gives a thief a problem. Will never let gas into my oil system and is easy to trouble shoot.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-12-2013, 07:05 AM | #5 |
78K & 79C Jimmys
I've run electric ,(anti theft reasons)once it stopped leaking,carb flooding it was good
now i'd run Mechanical cheaper and reliable
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-12-2013, 07:14 AM | #6 | |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-12-2013, 08:22 AM | #7 |
i think it really depends on what you are doing. for a stock dd to some mods mechanical all the way. high hp big cab then electric. but and this is just me. i think electric is great as was said prims the carb more even flow ect. if your truck is not a dd then go electric. wont get used enough to burn it out
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
04-12-2013, 01:24 PM | #8 |
I do believe the high pressure mechanicals are for race cars where reliability is king. For a street driven EFI truck, electric fuel pump undoubtedly. It primes the engine as it should. I don't miss the days of cranking my truck for 3 mins or more, it starts almost instantly with the TPI conversion.
Just don't buy a cheap Airtex pump like I did. Whines like a bastard. |
04-12-2013, 07:03 PM | #9 | |
either way, there both good & reliable for the street, just buy the best you can afford, |
04-12-2013, 08:24 PM | #10 |
yeller
mechanical, simple, cheap and reliable.
KISS
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-12-2013, 10:11 PM | #11 |
The durability is a big thing to me. Also it's easy to change out and if your in a bind a cheap store baught one will get you home
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
