Old 04-12-2013, 02:25 PM   #1
pinefieldfarm
pinefieldfarm's Avatar
'60-'66 Chevy 4wd w/rear trailing arms
I came across a '65 Chevy 4x4 longbed that someone was driving locally and got a chance to take a close look at it. The truck was to the best of my knowledge a 2wd to 4wd conversion because it had an open knuckle (Dana 44?) front axle with leaf springs and the stock coil spring/trailing arm rear suspension. I thought it was so cool that I've decided to convert my '61 2wd longbed to 4wd.
Has anyone here done this conversion or seen anything like it? Or did GM make 4wd trucks like this for any special reason? It seems like it would be far superior to leaf spring rear suspension, but would be limiting in regards to modifying and lifting the truck or rear axle.
pinefieldfarm is offline   Reply With Quote
Old 04-12-2013, 05:57 PM   #2
j.kirn
Re: '60-'66 Chevy 4wd w/rear trailing arms
why would it be superior
j.kirn is offline   Reply With Quote
Old 04-12-2013, 06:00 PM   #3
pinefieldfarm
Better articulation and softer.
Old 04-12-2013, 06:01 PM   #4
pinefieldfarm
By the way, nice K20!
Old 04-13-2013, 10:18 PM   #5
'63GENIII
'63GENIII's Avatar
Yeah I've seen it before. Only on an old (60s) something FJ something or other Toyota pickup. The guy had trailing arms out of an early 60 c20. Had a 14bff bolted to it. I'm not sure about how he had the pan hard rod in there but I do know it was REAL flexy and that he actually wheeled it pretty hard. It was a cool set up
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-05-2013, 09:34 AM   #6
bosephus
bosephus's Avatar
Watching this one, I've got a 61 long bed that I would like to convert. A 79 k-5 blazer may be the donor but keeping the trailing arms sounds cool. Hope someone with experience with this chimes in!
bosephus is offline   Reply With Quote
Old 06-06-2013, 01:25 AM   #7
argonaut
argonaut's Avatar
There is another post in here somewhere. Try a search.
I've seen a 72 2wd to 4wd conversion done this way. You cut the mount brackets off the axle tubes and remount them on top. You can then mount the axle beneath the trailing arms. You get lift without having to mess with new springs or the geometry of the suspension. Up front you can weld on or bolt on hangers and leaf springs and a solid axle from a 4wd donor of your choice. Don't forget the transfer case!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
