Old 04-12-2013, 07:29 PM   #1
61 chevy
61 chevy's Avatar
rear trailer arm coil spring ????
i want to lower the rear 2 inches, does anybody know how many coils that would be ? 1 or 2 or a half coil?
61 chevy is offline   Reply With Quote
Old 04-12-2013, 07:33 PM   #2
Reyals Bemus
Re: rear trailer arm coil spring ????
You can't cut the rear coils like you can the front coils. This is because the rear coil springs have pig-tail ends on BOTH ends. If you cut coils off of either end, it won't be able to bolt to the frame or trailing arms. People have done this and lived with it though. The best option is to order a pair of quality drop springs, such as those sold by ECE.
Reyals Bemus is offline   Reply With Quote
Old 04-12-2013, 07:39 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
You could use two inch blocks between the trailing arms and rear axle, with longer u-bolts....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-12-2013, 08:20 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The PO of my truck cut a coil or two and them welded the spring to the trailing arm. That worked fine until is put bags in the rear.. Just an option..
There also some different Jeep coils you can use to drop the rear some.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-12-2013, 08:29 PM   #5
Reyals Bemus
Yea I suppose you could cut em, and then make a little U bracket that would positively bolt the end of the coil to the arm. At least it then would not be totally ghetto.
Old 04-12-2013, 10:07 PM   #6
DLOE65
DLOE65's Avatar
get a set of factory newer rear jeep coils. my buddy found a set on craigslist for $20 bucks.. they lowered it about 3-4 inches and they ride nice and smooth.
DLOE65 is offline   Reply With Quote
Old 04-12-2013, 10:27 PM   #7
losthope
losthope's Avatar
You can cut them just have to figure a way to hold the top of the spring, even though i know a number of guys with daily drivers that just cut them and run them bolted to the trailing arms and nothing holding them to the frame and never have had a problem,but for safety concerns id never suggest it, I did it on two of my trucks and just used a u-bolt from the hardware store to hold the spring on top to the frame....but that does require you to drill some holes in the frame.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 04-13-2013, 07:40 AM   #8
tincan1966
tincan1966's Avatar
I would not recommend cutting the springs.
tincan1966 is offline   Reply With Quote
Old 04-13-2013, 09:44 AM   #9
chevyrestoguy
chevyrestoguy's Avatar
Don't cut the springs. Even if you can rig up a method to attach them, it's not a good option. These are your best three options:
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-13-2013, 10:03 PM   #10
63ChevC10
63ChevC10's Avatar
Do you know what year and model jeep will work?
63ChevC10 is offline   Reply With Quote
Old 04-13-2013, 11:09 PM   #11
bama63
bama63's Avatar
There are four different versions of the springs that were used from 1997 through 2006. These are the ones that can be used on the C10. Similar rear springs could be found on the Jeep Grand Cherokee ZJ. All four versions are the same length wise but vary in rate.
The only way to tell them apart is by the color coded tags that are on the springs from the factory, they read as follows:
103AA (or 3AA) 130lb.
104AA (or 4AA) 140lb.
105AA (or 5AA) 150lb.
106AA (or 6AA) 160lb.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 04-13-2013, 11:34 PM   #12
63ChevC10
63ChevC10's Avatar
Thanks!
Old 04-15-2013, 10:49 PM   #13
61 chevy
61 chevy's Avatar
thanks for all the suggestions. very helpful, can always count on this message board.
Old 04-15-2013, 11:13 PM   #14
slepysal
slepysal's Avatar
I went the jeep coil route. I got them off of Ebay for 15.00 shiped. They fit like a glove... But they dont let me carry much
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-16-2013, 12:56 AM   #15
63ChevC10
63ChevC10's Avatar
How much did it lower it? About 3-4 inches as stated above? I'm just trying to figure out what to do for the front if I go with jeep springs in the rear.
Old 04-16-2013, 01:40 AM   #16
slepysal
slepysal's Avatar
yea about 3 inches here is a before
and after
Old 04-16-2013, 07:46 AM   #17
63ChevC10
63ChevC10's Avatar
Attachment 1093235
Attachment 1093236
That's the look I'm going for. Looks good man!
Old 04-16-2013, 11:06 PM   #18
61 chevy
61 chevy's Avatar
i did 2.5 inch drop spindles in the front. this pic shows my old rear tires 275/60/15 they were a little balloonish. i just changed them for 255/60/15 looks better and they stick under the bed a lot better.
Old 04-16-2013, 11:57 PM   #19
slepysal
slepysal's Avatar
thanks 63chevyc10
