04-12-2013, 08:30 PM | #1 |
Bed mounted fuel cells...
I'm thinking pretty hard about losing both saddle tanks and putting a fuel cell in the bed. Anyone have any experience with this?
I'm thinking the pros would be more space under the body to work and run exhaust and a bed mounted fuel pump and filter would be easier to access and service.
1982 GMC C1500 4x4 w/ 305 and sm465. 2002 Kawasaki Ninja 250. 2007 Dodge Nitro. |
04-12-2013, 08:48 PM | #2 |
Re: Bed mounted fuel cells...
They work but you have to cut a hole in your bed for the fuel line.You end up losing alot of your bed and most of them don't have a way to add a fuel sending unit meaning you will run out of gas sooner or later.
I had one 20 years ago and it was always in the way.They are also harder to fill with fuel so if your married your wife will make you fill it up rather than climbing into the bed herself. If your young and single go for it. |
04-12-2013, 08:57 PM | #3 |
I'm not single but my wife doesn't drive the truck. I found an aluminum one that actually takes a GM sending unit. Do I have to cut a big hole? Couldn't I just cut a hole for the line and thread it through?
04-12-2013, 09:54 PM | #4 |
yeller
I mounted my 16 gallon cell under the bed, have a frame mounted battery, cal tracks, and 3" exhaust exiting behind the rear tires...there is plenty of room back there. In bed fuel cells look terrible IMO.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-12-2013, 10:40 PM | #5 |
SpaceMonkey
On the one I had there was a sump section on the bottom of the tank.You bolted it down in a bracket and drilled through the front of the bed not the bottom.I just ran 3/8 fuel line on mine and left the rest all stock. I used to ride motorcycles and ATV's and it took up too much room on a shortbed. If it has a gm sending unit and you don't mind losing some of your bed go for it.If you hate it you can always put your old tanks back in and sell it. |
04-12-2013, 11:22 PM | #6 |
Yeah, idk. The one I'm looking at is only going to take up 7 inches of the bed, it's 30 long, 7 wide, 17 tall. I have a long bed so it's not bad. I ride a motorcycle too, that's why I bought a truck, but I'll still have plenty of space.
As for looks, I'm all about function over form. I think I'll try it
04-13-2013, 01:09 AM | #7 |
yeller
What is the point of losing the saddle tanks? Going from 32 gallon capacity, to say 16? The saddles hold more, and won't get in the way of anything you may haul in the bed...doesn't sound more "functional". Don't make to mod just to make a mod.
04-13-2013, 07:20 AM | #8 | |
Even today, When traveling by motor vehicle I awalys drive and wouldn't be cought dead having a woman pump my gas.... old fashioned I guess..
04-13-2013, 08:36 AM | #9 | |
Addicted to Rust
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
04-13-2013, 09:02 AM | #10 |
When your out of town does your wife sit at home waiting for you to fill her tank(no pun intended)
I am not a big fan of my wife filling the tank either but if your not around and she needs to use the truck while helping one of her friends out it is usually best that she doesn't have a hard time of it. |
04-13-2013, 11:58 AM | #11 | |
04-13-2013, 07:09 PM | #12 |
I am debating rather I will put my gas tank in the bed, but it really depends on how much I lower it.
For me I would get a custom made tank about 6-8 inches wide, 14 inches tall so I can use a standard sending unit, and about 62 inches wide. That way it would run across the front of my bed, and not take up to much space in total. Then I would add two gas filler necks so it can go either way at the pumps. I figure I will end up with 25 or so gallons, and easy access for filling. |
04-13-2013, 07:54 PM | #13 |
When i did my flipkit i fabbed mine under the bed since i had the bed off anyway. Trap door in the bed to fill and your good to go.
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
04-13-2013, 09:08 PM | #14 | |
yeller
04-13-2013, 09:09 PM | #15 |
yeller
Here is a link to my fuel cell install
http://73-87.com/7387garage/chassis_...ellinstall.htm Posted via Mobile Device Posted via Mobile Device
04-13-2013, 09:48 PM | #16 |
Jeff
Nice clean install. |
04-13-2013, 10:28 PM | #17 |
why not use a blazer/burb tank?....fuel cells look like crap!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
04-13-2013, 11:03 PM | #18 |
I've been toying with the idea of fabricating a cover/box for the front of the bed that will effectively hide the whole cell and create storage space. Like a trunk in the bed. I think it'd look pretty sweet. If i build it I'll post pics. Big if.
