04-12-2013, 10:00 PM | #1 |
Windlace install ??
OK, are there any tricks to installing windlace. Mine is the type that needs to slide into a track around the door opening.
I only messed with it for a minute but it sure seemed like it is going to be tough. I was thinking soapy water or a little WD-40 might help. Let me know if there are any tricks. Thanks in advance Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-12-2013, 10:41 PM | #2 |
Re: Windlace install ??
I used soapy water on one side, pushed and pulled and after what seemed like forever, finally got it all in. It made a mess and my hands were killing me. The other side I just used a flat bladed screw driver and went around pushing the rubber into the metal trim and was done in less then 10 minutes.
Good luck. |
04-12-2013, 11:20 PM | #3 |
One of those plastic tools they sell for pushing windshield rubber in or out would work pretty well to push it in or a wide blade flat tip screw driver out of the cheap tool rack that you have rounded and smoothed the tip on to make a special tool out of it if you don't want to poke the material with a screwdriver. Start at a bottom corner and tuck a few inches of the windlace into the slot and then roll the other edge in the slot with the tool and repeat until you have it done.
04-13-2013, 03:43 AM | #4 |
Silicon spray will help a ton!
04-13-2013, 07:20 PM | #5 |
Thanks guys..like I said, I only played with it for a few minutes. Thanks for the suggestions. I will give it a try when the weather warms up..
Marc
04-13-2013, 11:50 PM | #6 |
................... that is all it takes.......a few minutes every day for about a week. You will know when you are finished!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
