04-13-2013, 01:22 AM | #1 |
more starter problem
Jve been messing with my starter alot because it makes a crazy clunk noise when i turn the key.....its got to be a miss alignment problem,ive replaced the starter twice ,once because i thought it was bad,another because it sheered all the teeth off the gear, ivgot one set of shims that came with the starter and a another i had to buy.....ive tried every level of shimming and still the loud noise.....its like the starter is banging itself against the flywheel....flywheel is in great shape.... anybody got any ideas?
Posted via Mobile Device |
04-13-2013, 09:38 AM | #2 |
Re: more starter problem
Are you using the right bolts and do you have a starter brace?
04-13-2013, 10:07 AM | #3 |
Junior Member
What kind of starter are you using, a stock starter or a mini-high torque?
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-13-2013, 11:24 AM | #4 |
Its a stock starter and and the right bolts.....what the hell is a starter brace
04-13-2013, 12:30 PM | #5 |
04-13-2013, 02:13 PM | #6 |
You cut the shims in half if you want it closer. I usually pry out the gear and check for tooth depth and engagement
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
