Options sticker location??
Hello, I was just looking over a 75 custom deluxe and cant seem to find the options sticker. I looked in the glove box, nothing, checked the 1 door i could open, nothing. looked at the drivers fender well under the hood, there is a square where adhesive was, i'm thinking that was the spot? any help is highly appreciated. thanks!
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax ![]() Last edited by Brockwaykid; 04-13-2013 at 11:07 AM. Reason: change year |
Re: Options sticker location??
every square i've ever seen had the spid in the g.box, but you never know. the adhesive on your inner was probably a jack decal or w.washer sticker. try looking in the back of the seat for a build sheet
#3 | |
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax ![]() |
well, it wasnt behind the seat either. dont know where else to look!
![]() Join Date: Feb 2011
My 73's was located on the drivers fenderwell.
MusicMan70 1961 GMC Suburban |
thats where i saw one on another truck on here, i think thats what the adhesive square is from on this truck. bummer.
it was removed by original owner and I do have it
huh, the one i'm looking at was pretty much on the other side of the inner. more towards the firewall, on the curve. but def. the same size.
![]() Posted via Mobile Device
yup older trucks had them on fenderwell
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Junior Member
I can't find a SPID on the '75 C-30 I bought not long ago either.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
My 75 Blazer is in the glove box
#13 |
I'm not sure but I remember reading about it here or another forum I am on but I searched and cant find it....maybe I'm mistaken
hopefully Keith or someone more knowledgeable will reply to this thread.
#14 | |
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
#15 |
Maybe location was dependent on Factory. My 73 was built in Fremont.
#16 |
From the ones I have seen they were on the inner fender on some 73 to 76 units
All the 77 and newer that I have seen were in glovebox I think it did depend on the plant Janesville and Fremont also seemed to put the paper build sheet in the seat springs |
#17 |
I bet it was on the fender well and someone took it off. man that bothers me.....
#18 |
I looked at a 74 lwb big block 2wd it was in glove box I also have a 85 k10 and same place. My 84 k10 is on driver inner fender
Posted via Mobile Device |
#19 |
well,seeing how the model yrs are all over the map on inner fender stickers, it's probably a plant thing. i wonder why, you'd think they would be one size standardized across the board. which plants used them? anyone with a inner sticker want to post what plant
#20 | |
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
#21 |
I can't help with the specifics but would like to add some "color commentary" -
a) The adhesive label in question is the SPID label (aka "Service Parts ID label). My recollection is that '73-80 was on the fender well and '81 - '87 was in the glovebox. That might be too simplistic, though; I will keep my eye open for documentation as I go about other things. b) Differences between plants: there has always been a desire for plant process to be common but that is a very difficult thing to do. Keep in mind at this time there were 7 plants producing these vehicles, each with a distinct history (in terms of prior products, and in terms of plant "ownership"). This results in immovable objects on the assembly floor that have to be worked around and in precedence that is difficult to overcome. Hence the variation between plants. (Heck - there is even variation between processes on different lines within the same plant). c) The paper sheet found under the seat is different altogether: that's the build manifest (or build sheet). Seats were built up in a separate area of the plant (aka "the cushion room") and the specific build options were conveyed via these build sheets. They were supposed to be thrown away when done but it was simply easier to just leave them in place and build the seat up around them. I have never found a build sheet in any of my collector cars (except one) so you are very fortunate to have one. That specific document is not housed or stored in any official collection and exists only if you find it in the vehicle. I wish now I had thought to keep them when I was watching my truck get built. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-15-2013 at 09:39 AM. |
#22 |
I should add: my Flint built '87 had the SPID label in the glovebox -
![]() and I did find one build sheet. This was above the fuel tank on my '65 GTO, built in Pontiac Michigan: ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#23 | |
If you need to know what it left the factory with maybe the GM Heritage package is available for your truck. Maybe Keith knows what years they are available for and will chime back in. Frank
Born and proudly residing in a Red State ! |
#24 | |
Unfortunately the Heritage Center does not have documents available for our trucks until 1977. The only other option would be if the truck was built in Oshawa: GM of Canada does have build records for those vehicles either built in Canada or destined for the Canadian market. K
#25 |
Slots go on anything!
Just to be the odd duck, my '74 has it in the glove box. I was a little suprised to find it there.
