Old 04-13-2013, 01:08 PM   #1
monterx7
transmission needle bearings
i tried searching but came up with nothing. not sure where to look for this info. i pulled the tail cone out of my 3-speed trans, and as im sure many of you know, all the needle bearings fell out. after removing the trans, i dug out as many needle bearings as i could see(ended up with 2 different thickness bearings). i need to figure out if i found all of them and where/what order they go in.
any info you guys can provide would be greatly appreciated
monterx7 is offline   Reply With Quote
Old 04-13-2013, 01:46 PM   #2
Rufton
Re: transmission needle bearings
Needle bearings can be held in place w/ grease during install. There should be enough bearings so no more room for another needle bearing.
Rufton is offline   Reply With Quote
Old 04-13-2013, 07:15 PM   #3
gofastnut
gofastnut's Avatar
Hey, I did the same thing, DOH!
Is the trans out of the truck? I used one of those little telescoping magnets to see if there were any more in the bottom. I used some drum brake wheel bearing grease--thick & tacky--and put the needles on-come to find out I was one short, got the magnet and dug around again, found it on the floor 15 min later. It took me about an hr of trying to FINALLY get it centered right and in.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-13-2013, 09:21 PM   #4
monterx7
yeah the trans is out. i dug around with a magnet like you did and found alot of them. i was hoping i could find out how many im suppose to have.
right now i have:
21 small
14 big
Old 04-14-2013, 12:10 AM   #5
Rufton
Add shaft radius to bearing radius then calculate circumference (of bearing center). Divide circumference by bearing OD to get number of bearings plus play. Play is less than one bearing. For example if calculate 15.3 then need 15 bearings.
Old 04-14-2013, 11:52 AM   #6
monterx7
what does all that mean in english???
Old 04-14-2013, 12:33 PM   #7
padresag
it means that if you put all your needles in the outer race and there is a little space left over, but not enough room to fit another needle you are fine. vaseline is fine for holding the needles in place.
ron
padresag is offline   Reply With Quote
Old 04-14-2013, 01:32 PM   #8
monterx7
did you have 2 size needle bearings like in the pic i posted?
Old 04-14-2013, 01:38 PM   #9
monterx7
ron
that makes sense....thanks
Old 04-14-2013, 01:38 PM   #10
Rufton
ron
Old 04-14-2013, 06:56 PM   #11
monterx7
alright well ive tried to figure out where these darn bearings go.....does anyone have a pic or reference that would help me out
Old 04-14-2013, 07:14 PM   #12
monterx7
is this where they ride along?
Old 04-14-2013, 07:52 PM   #13
padresag
it shouldn't be hard to figure out. just lay them side by side. the longest should go to the larger circumference, mind you one is larger than the other. they are going to fit where they belong
ron
Old 04-15-2013, 12:30 AM   #14
monterx7
well this is the way i ended up installing everything...this week or weekend ill see if i put everything back where it belongs
Old 04-15-2013, 12:52 AM   #15
gofastnut
gofastnut's Avatar
Yep, that brings back somewhat unpleasant memories. Looks right to me. I wound up using heavier grease because it was hot and the needles kept falling off with vasoline.
Good Luck!
Jeff
C-10 Club
Old 04-15-2013, 01:46 AM   #16
padresag
easier to put them into the external race, they can't fall off
ron
Old 04-16-2013, 12:57 AM   #17
monterx7
yep thats how i did it ron.
