![]() Join Date: Dec 2012
Did these body mounts need replacing?
I started replacing the cab mounts on the truck today. I found a couple of them that may have been bad. What do you think?? I also stopped after the rear mounts because I have a couple of questions. Are the front cab mounts on an excentric bushing for adjustment? I did mark the cab position on the frame. Are the core support mount bolts carriage bolts? Mine won't come loose and the bolt turns with the nut. I can't fell a hex head on them. I'll pull the radiator to get a betther look at things. I did take it around the block with JUST the rears replaced. It already feels MUCH more solid. Thanks in advance for advice.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 04-13-2013 at 03:58 PM. |
