Help! Crack in frame?
I was fixing a coolant leak in my 70 and to my horror noticed a crack in the frame around one of the unused motor mount holes on the passenger side, top of the rail. I bought the truck about six months ago and can't believe I didn't see this. The question is how do I fix it? I have a mig welder... Can I just run a bead on it or is this something that will require some professional attention? I've tried to attach some photos and would appreciate any advice...
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: Help! Crack in frame?
Here's another view...
And the truck itself...
If the frame is still straight, I would weld it up and then weld in some reinforcing plates.
However, a crack like that would lead me to believe that major front end damage happened at some point. You may have more issues than just that crack. I'd have a shop check it for any additional damage and check to see if the frame is still straight.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
^agreed.
If frame is str8 and no other damage weld n reinforce. Do a search on crack repair on google because there are good ways and lesser ways to repair cracks. My 2 cents Posted via Mobile Device
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
![]() Join Date: Feb 2007
since the motor is in the truck right now perhaps a guy could hang 4 plum bobs, one at the front horn and one at a designated spot back further by the fire wall off of each frame rail. Use a tape and cross measure for squareness. This may help desipher if the front is out of wack and give a guy an idea if further investigating is needed before burning iron.
Little surprises like this can catch a guy off gaurd. Good luck with the project. -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
![]() Join Date: Mar 2011
Verify as best you can if the frame is straight----chek to see if the truck drives straight (flat pavement, measure front tread width then back tread width----wet tires slightly, drive it forward at least one full truck length (or more), see that it is tracking straight-----if its all straight , drill a small hole at the end of the crack to stop any growth of the crack---then lay a good bead on top and on bottom of the crack (if you can get to it). A couple Good welds and it will be stronger than before.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Open it up a bit and get a nice full penetration weld to sew the gap up. Shouldn't need to worry about adding reinforcements if the weld is fully penetrated.
![]() Join Date: Jan 2007
Dont forget to take the battery out before you weld on it!
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. ![]() |
I finally found a shop with the interest in welding this for me - and fortunately I got really good vibes from them. Also, the welder thought it was a <$100 job. A belated thanks for all the advice and responses I got on this thread! This site is amazing, and I've been able to answer so many of my questions just using the search function. If I have a question, chances are it's been asked more than once here.
![]() Join Date: Oct 2012
did you go to a frame shop? need to know how the crack got there...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
![]() Join Date: May 2012
bad news on the crack....hope you get it fixed and everything is o k .
#13 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#14 |
Drill a small hole at the end of the crack to ensure it doesn't propagate, then weld it up. Ensuring first that the damage is local to just the crack as mentioned above.
