Old 04-13-2013, 11:10 PM   #1
yossarian19
Six lug rear end options on TF?
I've got the stock rear end in there at the moment. Putting a 4.8 liter LS motor + 4L60E in, planning to drive it a lot and want to keep six lug pattern.
Are the stock rear ends any good? I'm skeptical that it will hold up, dunno why.
Will a C10 12 bolt work, or will the wheels stick outside the fender line?
yossarian19 is offline   Reply With Quote
Old 04-13-2013, 11:51 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Six lug rear end options on TF?
67,68 and 69 c10 and K10 1/2 tons both had 6 lug and WMS (wheel mount surface) is 62 1/2 with the same 1310 u joint that yours has.
NEWFISHER is offline   Reply With Quote
Old 04-14-2013, 12:06 PM   #3
_Ogre
_Ogre's Avatar
^^ aren't those all open spool one wheel wonders.
shop air compressor timer
Old 04-14-2013, 04:50 PM   #4
Mac the Yankee
You could put a V8 Toyota truck rear under it- same bolt pattern and (I think) same width.
Mac the Yankee is offline   Reply With Quote
Old 04-14-2013, 10:58 PM   #5
mknittle
mknittle's Avatar
Not all of them. here in the sierra foothills lockers and limited slips are about 50% the ones I have seen. Mostly limited slips
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-15-2013, 03:12 PM   #6
Katrina/10
Katrina/10's Avatar
Anyone ever try an AWD Astro van rear axle? those are 6 lug.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 04-15-2013, 03:37 PM   #7
thotfulspot
You can change bolt patterns on most axles if they have the room.
http://www.dutchmanaxles.com/services
thotfulspot is offline   Reply With Quote
Old 04-15-2013, 08:57 PM   #8
yossarian19
I think the Astro uses a different pattern, like 6 on 5 or something silly.
I'll keep an eye out for those C / K10 axles. The Toyota might get used, but while I'm on a roll with keeping it Chevy I think I'll try and continue the trend.
Old 04-16-2013, 09:32 AM   #9
sqrlnts
I used a 10 bolt out of a 68 C10 in my 57. Direct bolt in outside of shock mounts. Nevermind the panhard bar, that didn't work out.
sqrlnts is offline   Reply With Quote
Old 04-16-2013, 09:52 AM   #10
Katrina/10
Katrina/10's Avatar
How did the width on that 68 compare to the original axle?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 04-16-2013, 11:35 AM   #11
sqrlnts
IIRC, they were the same at 61"
