Old 04-13-2013, 11:39 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
Talking main seal
my 327 is leaking oil,how do i find out if its leaking from main seal.and if so,how dificult is it to replace it?
1966FLEETSIDE is offline   Reply With Quote
Old 04-14-2013, 12:39 AM   #2
Rufton
Re: main seal
I guess the first step is making sure it's not valve cover, intake or tranny.
There is a chance ( I'm guessing 1 in a 1000 chance) a high mileage oil w/ seal conditioner or just seal conditioner will help unless the seal has hardened too much.
A 2 piece procedure is dropping pan then rotating upper half out by pushing w/ something like a chop stick. Then rotate new one in.
Rufton is offline   Reply With Quote
Old 04-14-2013, 12:48 AM   #3
1966FLEETSIDE
Re: main seal
thx rufton.well i did change valve cover gaskets and tranny,how do i know if its main or just oil pan.
Old 04-14-2013, 01:13 AM   #4
Rufton
Re: main seal
That's a good question but have to drop pan either way. Seal leak may sling oil inside bell; pan may not.
Can snug pan bolts just don't bend it; slight chance that will help.
Old 04-14-2013, 01:15 AM   #5
donthekawguy
donthekawguy's Avatar
Re: main seal
Mine is leaking like crazy also. I'm just waiting till I'm motivated enough to fix it. lol
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-14-2013, 07:45 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: main seal
The first step to fixing any oil leak is to get the engine clean. Real clean. Then get under it and look for where its coming from. You can't diagnose anything with oil all over it.
Old 04-14-2013, 08:13 AM   #7
brokenspoke
brokenspoke's Avatar
Re: main seal
The rear of intake manifold or oil pressure line would be my first check
brokenspoke is offline   Reply With Quote
Old 04-16-2013, 12:09 AM   #8
1966FLEETSIDE
Re: main seal
thanks to all of you for the great tips.
