Old 04-14-2013, 04:47 PM   #1
rideblue00
rideblue00's Avatar
Need pics 66 th400 kick down harness
Looking for what the kick down harness looks like for the turbo400 on a 66.. I have a box of spaghetti to look through and dont know what it looks like.
thanks
rideblue00 is offline   Reply With Quote
Old 04-14-2013, 04:58 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Need pics 66 th400 kick down harness
Isn`t the 65 / 66 th-400 a mechanical linkage, I thought that they didnot start electic kickdown until the 70`s....
Here`s a pic of a 70`s kick down switch if that helps
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-14-2013, 05:32 PM   #3
rideblue00
rideblue00's Avatar
i know this truck was stock as my gramps gave it to me and he always took great care of his stuff. This is what the switch looks like.
Old 04-14-2013, 05:57 PM   #4
Rich 5150 69
Wiring color should be the same, looks to be red and pink with a plug in your harness..
Old 04-14-2013, 10:20 PM   #5
yelmer
orange yellow wire orange to trans ,yellow to wiper motor
yelmer is offline   Reply With Quote
Old 04-14-2013, 10:26 PM   #6
yelmer
the bracket and switch are correct from ride blue. the turbo 400 (375) trans used that setup in 1966 one side of the bracket mounts to the rear carb stud the other mounts to the coil bolt hole
Old 04-15-2013, 12:46 AM   #7
HOTFUN
HOTFUN's Avatar
Exactly as Yelmer states as I am taking the original T400 out of my 66 C20 parts truck now and trying to duplicate a totally correct install in the C10 swb. That yellow wire on the 2 terminal kickdown switch you have pictured has a single black plug and goes up to the grommet in the center of firewall in the same grommet the oil line passes through and then inside over to the wiper motor and will have a 2 connector jumper wire end of a yellow wire and a blue wire to go in between wire harness and the wiper motor plug in.
Mine is missing the orange single wire that runs down to the terminal on tranny. Trying to find the wire or just the correct plug in for the tranny to make up this wire.
e
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 04-15-2013, 07:52 AM   #8
1966c10shrtbd
1966c10shrtbd's Avatar
http://www.summitracing.com/parts/bmm-20297
1966c10shrtbd is offline   Reply With Quote
Old 04-15-2013, 08:55 AM   #9
yelmer
factory fit wiring harness, have the wire, I gave them mine a few years back they copied it. they now have it in there catalog .
Old 04-15-2013, 11:59 AM   #10
rideblue00
rideblue00's Avatar
looks like american autowire heas it like yelmer said. part #38801
ha, no pic tho. which is what i need. i dont know what the connector looks like.
Old 04-15-2013, 09:32 PM   #11
yelmer
here are some shots, single wires
Old 04-15-2013, 09:39 PM   #12
rideblue00
rideblue00's Avatar
Cool. Thanks yelmer!
