Old 04-14-2013, 06:16 PM   #1
tismy55
400 w/Transfer case Vs 700 r4 w/transfer case
Which is better to run in my 65 4x4 I have an 82 400 w/transfer case,and a 85 700R4 w/ transfer case. Which one would perform better for my 65 4x4 for street use. I'm running 350 v8
tismy55 is offline   Reply With Quote
Old 04-14-2013, 09:51 PM   #2
t4keumbw
Re: 400 w/Transfer case Vs 700 r4 w/transfer case
Its all according to what you are after. If you are driving long distances, the 700r4 would be the better choice because it has overdrive. It will reduce the rpms on your motor and increasing fuel mileage.
The 400 is a tougher transmission and will put up with more abuse but its still a 3 speed trans. So the fuel mileage will go down and the rpms on the motor will be higher.
t4keumbw is offline   Reply With Quote
Old 04-14-2013, 09:52 PM   #3
t4keumbw
Old 04-14-2013, 09:56 PM   #4
'63GENIII
'63GENIII's Avatar
Don't know much about the R4. The 400 is super tough though. Towing a lot? 400. Seldom towing? R4. I do like overdrive though!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
