04-15-2013, 08:56 AM | #1 |
water pump
what would make a water pump come lose. It was tighted to the torque specs.. 72 k20 350/205/sm465. man i throught i blew a head gasket. somthing i dont want to hear right now..
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric |
04-15-2013, 09:08 AM | #2 |
Re: water pump
did u use thread sealant or lockwashers?
04-15-2013, 09:45 AM | #3 |
Re: water pump
perhaps a cheap failed gaskets(i had this happen once when i use the crappy gaskets that came with the wp) worn bolts or threads or a balance problem hanging off the front of the pump
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-15-2013, 11:17 AM | #4 |
Re: water pump
Gasket or sealer may compress resulting in loose bolts.
RTV makes cleaning flanges easier; but RTV increases chance of needing to re-torque. I assemble ASAP with a thin wet film of RTV is between gasket and flanges. I prefer thread sealer that allows re-torque; but is more likely to back out if gasket compresses. Perhaps permatex hi-tack is a good compromise because it sets up slowly giving some time for re-torque but kinda locks bolt over time. |
