Old 04-15-2013, 02:42 PM   #1
Bierkan
Bierkan's Avatar
Glue-ing vs Stock Rubber for Windshield
We've had a lot of rain this past week. I know my truck has a leak in the windshield somewhere. I think I found it this past weekend. It appears to be leaking around the rubber seal around the windshield. I'm sure when I pop the shield I'll find rust and such. AFAIK, it's stock. Looks like someone in the past tried some silicone to seal a leak.
So, my Q is, when I go to replace the glass, is it advisable to use the more modern process of glueing the shield in place or use the stock style rubber? This is a rat-rod-ish truck so I'm looking for function vs. OEM look. This truck will spend more time outside than in a garage (due to space) so it has to withstand water.
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
Old 04-15-2013, 07:43 PM   #2
OrrieG
OrrieG's Avatar
Re: Glue-ing vs Stock Rubber for Windshield
Denee ended up installing hers with the "Modern" sealing method with the gasket acting as trim. She got the truck without a window and found it had some fitment issues that would not allow the window to seat in the gasket. Check out her thread.
OrrieG is offline   Reply With Quote
Old 04-15-2013, 07:46 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Rat rod or not you don't want it to leak and not to rot. I'd strongly advise Steele Rubber Products ONLY - I've never read a bad comment about them. And install it like it came from the factory.
Dan in Pasadena is offline   Reply With Quote
Old 04-16-2013, 02:12 PM   #4
98layinframe
98layinframe's Avatar
Anyone have pictures of the more modern flush mounted style glass?
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 04-16-2013, 02:16 PM   #5
focusedontheprize
focusedontheprize's Avatar
I just put my 2 piece windshield in this weekend. I used the rubber gasket and will be going around it with urethane in the coming weeks. I was debating on doing the modern, but I wanted the rubber in there also. I am not too worried about the leakage.
focusedontheprize is offline   Reply With Quote
