Blazer top
I have asked about 3 or 4 times and can't seem to get an answer on how to remove the handle from a blazer hatch.
I really need some help on this one guys bc I'm about to just cut it off with a grinder and buy a new one. I would rather have the original one and just get the cylinder fixed Posted via Mobile Device |
![]() Join Date: Jan 2007
Re: Blazer top
Here you go - I used the search feature to get your answer:
Post #5 in this thread explains the process This post describes the way to remove the lock cylinder from the handle: Removing Lock Cylinder This thread breaks it down further with more pix of the internal workings of the hatch: Handle breakdown Hope that helps - good luck. |
Re: Blazer top
Ok thank you I was able to get it out. So my next question is the key doesn't work I'm not for sure if its the wrong key or if its just froze up. So how do I get the escutcheon off of the handle that way I can get the cylinder out
Re: Blazer top
here is the link to the instructions.. http://67-72chevytrucks.com/vboard/s...d.php?t=503101
I used these instructions for mine and had a locksmith shop re-key it. worked great. oops, did not notice they reference the same link above. Last edited by PD1292; 04-16-2013 at 01:14 PM. |
Re: Blazer top
I tried these steps but since my key wont turn the cylinder I can't get the beauty ring off which means I can't get the cylinder out
Re: Blazer top
does anyone know how to get the beauty ring off since the key doesnt work
Re: Blazer top
I dont think it is possible, but you could pm locdoc as he is the sme. If you want to experiment, i have a beat up handle in the same state of disassembly as yours
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
