Factory coils to leaf spring help
Re: Factory coils to leaf spring help
Hey don't know what the hell just happened but here is my question, I have a 70
Short wide and was wanting togo from the factory coils suspension to factory leafs off a 71 . What kind of issues will I run into ? I know I'm not the first to do it . Posted via Mobile Device |
![]() Join Date: Jul 2012
I'm currently doing this swap myself, but I'm doing it because the coil spring frame was rotten (well, at least more rotten than the leaf spring frame). I do know that the frames are different over the rear axle, though. The coil spring frames, at least the 3/4 ton versions, have double wall sections through the axle hump area.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
Well mine is already C notched and boxed already just for the clearance on the 5" drop springs that looks like was a waste of money seeing how the truck is still under construction.
![]() Join Date: May 2002
Half ton 2WD frames are the same, coil or leaf. Shouldn't have any problems, as long as you measure and measure again. Do you already have the leaf spring brackets?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Yea the guy claims it all came off a 71, leafs , shackles, hangers everything a 100 bucks . Hope I didn't over pay and if I did then that's my life story
that's not bad, but what about the condition? where they sandblasted and primed? any pitting?
Yea in good shape the guy went four link and air
Ok guys just got the truck on my lift and from looking at my brother in laws truck his is a factory leaf truck and it seems that my bumper brackets are going to be in the way of some bolts for the hanger . Guess I need to just start pulling a tape measure and just get it . Any advice would be greatly appreciated .
![]() Join Date: Mar 2013
Instead of starting a new thread, what is the advantage/disadvantage of coils/vs leaf springs? In theory coils sounds better for ride. I figured GM gave up on them in later years mostly for money savings and simplicity.
To me leafs are a steadier ride and won't give that side to side up and down rotation you get from a car that has a bad shock . I guess it just comes down to preference . Hell , who knows I'm probably just wasting more money !!!!
Actually I know what you mean my 1/2 ton does kinda feel like it needs shocks in the back when it doesnt.
