Old 04-15-2013, 09:59 PM   #1
Bchain
A new truck & how low is it?
Well I've been lurking on this forum for about two years now while working on this truck. Really stinking amazing how much knowledge you guys have, I've been learning by osmosis just browsing around.
This is a 73 c10 stepside and it has a family story, at some point I will put together a build thread. Want to get a bit further on it first. Those threads are no good without a ton of pictures.
For now I have a question. The truck was lowered in the early 70's (heated springs in front, removed leafs with air shocks in back). I am in the middle of a full frame teardown and would like to replace the coil springs (am thinking I can get away without spindles, after all that's how it is done right now).
Figure some practiced eyes can look at this thing and tell me what springs I should order. Guessing 2" but would hate to get the wrong ones.
Tires are 295/50/15 if that helps. Old school hotrod. Can't see the front real well in the second pic but proves that she isn't covered in bird crap any more.
Brian
Bchain is offline   Reply With Quote
Old 04-15-2013, 10:04 PM   #2
Joe69C10
Joe69C10's Avatar
Re: A new truck & how low is it?
Looks like 2" in the front to me. Congrats! Nice truck!
Joe69C10 is offline   Reply With Quote
Old 04-15-2013, 10:05 PM   #3
Ziegelsteinfaust
my guess is 2.5 or 3 inch front, 5+ rear.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-15-2013, 10:25 PM   #4
Bchain
2" to 3" makes sense at least, that would be the range I can get with lowering springs (at least based on Summit's options).
Surprised to hear 5" in the back. Suppose it could have been low on air, there is a pretty good adjustment in those air shocks. The back has all but one leaf and the helper leaf removed. I think that the rest of the setup back there is stock, except for the shocks. Not sure how many leafs are normal for a 2wd half ton?
Anyway, I forgot to mention that before I tore the truck down, if it was just sitting on the garage floor, I could just barely slide under the exhaust. So it isn't on the ground or anything.
Joe, that's a nice looking truck you've got. Helped my father in law buy an 86 that looks just like it, minus some trim.
Old 04-15-2013, 10:28 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Nice truck! Regardless of what you have I suggest you go with 2" springs. Anything more and you wont like the ride.
Dont be afraid of dropped spindles. I would run them first and springs later.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-15-2013, 11:53 PM   #6
Ziegelsteinfaust
I second this.
Old 04-16-2013, 06:14 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
3 inch drop coils ride horribly. This is a lesson I learned the hard way.
Old 04-16-2013, 07:07 AM   #8
bigd65
bigd65's Avatar
2 inch coils are not BAD, but don't ride like factory. I do like the steady ride of the 2inch, but going back with the factory springs when my spindles come in
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 04-16-2013, 07:08 AM   #9
bigd65
bigd65's Avatar
And from the looks of that picture, that sure is a nice truck
2017 Chevy Tahoe
Old 04-16-2013, 10:22 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Amen brother. Lesson learned myself.
Articles-
"Refining Sierra"
Old 04-16-2013, 10:31 AM   #11
DREAMER1
DREAMER1's Avatar
X2 on the drop spindles...I'd grab a set of factory springs from the salvage yard an dropped spindles. 2"or 2.5"
The rear does look like a 5" in the rear.
DREAMER1 is offline   Reply With Quote
Old 04-16-2013, 08:06 PM   #12
Bchain
Thanks!
It's a bit rougher up close, needs paint and a bit of body work. Not much rust at all though. Couple of things that have been done to it over the years that I would not repeat, including the heated springs (maybe defendable since that was done in the seventies).
Old 04-16-2013, 08:10 PM   #13
Bchain
Dreamer, good call on the junkyard springs. Cheap and frees up money for spindles, which sounds like the better way to start.
Are 2" drop spindles equal to 2" lowering springs? Good source on spindles?
Also, what is the best plan if the front end is too low/high after reassembly? I'm thinking 2" drop spindles and then I can always add lowering springs if necessary? Is there a better approach?
Old 04-16-2013, 09:28 PM   #14
slugish
Slugish
yea , got 3 in. drop springs on mine > not a very pleasasnt ride
slugish is offline   Reply With Quote
Old 04-16-2013, 10:44 PM   #15
J Knight
J Knight's Avatar
I think these questions would be easier to answer if we know how low you want to go in relation to where it sits now(looks 2/4in to me) and if you are keeping those slot wheels and tires. From what I can see in the pics you will have rubbing issues if you go any lower. I would definitely start with a fresh set of spring front and rear(new or used).
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-17-2013, 06:12 PM   #16
1977cheyenne_C10
1977cheyenne_C10's Avatar
Nice truck man. ive always been a fan of wide rims (15x10).
1977cheyenne_C10 is offline   Reply With Quote
Old 07-09-2013, 08:04 PM   #17
Bchain
Good question, I am trying to maintain the stance it has in the pic up top. Do NOT want to go lower, no 6" drop plans here.
I am also trying to keep the 15" mag slots and 295s on it. These wheels have only a 3.5" back space (van wheels?), from what I read this should mean that I won't need to trim on my lower control arms if I do drop spindles...
From much reading of others posts I am thinking 2.5/4 will give me a level drop...sound right? I am going with air shocks on the back end so I can adjust somewhat to match the front...
If I only need 2" I am tempted to just do springs as 2" spindles seem rarer.
Old 07-09-2013, 08:06 PM   #18
Bchain
Look at slonaker's truck in this thread. Looks right to me and he says 2.5/4 got him a level drop...
http://67-72chevytrucks.com/vboard/s...el+stance+drop
