Old 04-15-2013, 11:42 PM   #1
Brandon_70
LSX swap questions
I finally got my motor built and need to figure out a few small details. My first question is, can I use my stock transmission crossmember for my 5.3/4l60e swap and just get a new mount? Next, will a radiator/fan set up out of a 98-02 Camaro fit perfect into my truck? My truck is a 1970 C10 SWB that had a factory 350/350 set up. Thanks for any advice.
Brandon_70 is offline   Reply With Quote
Old 04-16-2013, 02:13 AM   #2
ls1nova71
ls1nova71's Avatar
Re: LSX swap questions
You can use your stock trans crossmember and the stock 350 turbo mount, it will bolt to a 4l60e, you just need to use the metric bolts.
The Camaro fans can be made to work with a litle fab work, I wouldnt say they will fit 'perfect', but will definitely be good.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-16-2013, 07:34 AM   #3
Brandon_70
Awesome, thanks for the reply.
