![]() Join Date: Jun 2011
Early Classic 4/6 drop .. who has it? What's your thoughts?
Been contemplating a 4/6 drop for my 69 short bed and have read many, many threads but can't seem to find much information on what people actually think of them in ride quality and whether or not the kits are complete. They sure make the truck look good and I'm sold on that aspect, but I would like to hear from people who actually have a 4/6 drop installed on their truck.
I have already converted the front over to disc brakes. One of my main concerns is I don't want to spend $750 on the kit only to find out I need to spend another $400 to make it work. thanks in advance. |
Re: Early Classic 4/6 drop .. who has it? What's your thoughts?
The information I've gathered from other members.
Members will also ask what size tires and wheels you plan on running. 1. What's the ride quality like? I hear the ride quality is great. 2. If you do have the Early Classic kit.. Is it complete? I don't have the kit, but it appears to be complete and I have not heard otherwise. 3.Did you have to buy anything else to make it work? Not that I know of. 4.Does your truck slam on the rear axle on mild bumps? I've heard/read from some you need a c-notch and some say you don't. Some people will suggest a c-notch if you plan to do occasional hauling. If you plan on just using it for regular driving, a c-notch is not required. I bought a c-notch from Porterbuilt and I just plan on using my truck for regular driving. I just wanted that extra clearance so that it doesn't bottom out on minor bumps or unexpected potholes, etc. 5. Can you still haul stuff in your truck without problems? Depends on the load capacity. 6. Are they're any problems making the kit work or is it pretty much install and go? I've heard it was a straight forward install. Only thing that had to be changed was the relocation of the shock mount brackets. All of this is info I gathered from other memberes. I've been doing my homework myself. I'm sure others will chime in soon. |
Hey Jimmy, I have the ECE kit on my truck and I am very satisfied. The only difference in mine is I had them swap the 1.5" spring for a 2" spring to get a 4.5" front drop. Here are my answers to your questions.
1. Ride quality is very good. Its not a Cadillac, But it is far from rough. I noticed a HUGE difference in the way mine handled as compared to stock. Even with no swaybars. (yet) 2. The kit is complete. I replaced ball joints and tie rods when I did mine, but I dont think any kits will come with those. There was nothing else I needed to complete the job. The kits include all the high quality hardware you will need. 3. As I said above, the kit included everything 4. I put notches in mine and I am glad I did. Mine has never bottomed out that I know of, but without a notch you would definitly hit the bumpstops from time to time IMO. They (ECE) say it's pointless to put notches in because the rearend will hit the bed floor before you hit the bumpstop in the notch. But my thinking was, with notches you eliminate the stock bumpstop and give yourself a couple more inches before bottoming out. My rearend has never hit the bed floor. So I think its really up to you. You'll get varying opinions on this one. I would put in the notches on again if I ever do another one. 5. I havent hauled much with my truck. I did haul a complete small block in it and that was about as much as I would want to put in there. I guess it depends on what your needing to haul. Some odds and ends, yes its fine. A load of sand...I wouldnt. 6. The kit went together very well. To me, the worst part it getting those old rivets out of the frame for the shock relocators. But this has nothing to do with the kit. Over all, I would highly recommend ECE. The parts are very well made. Hope I helped a little
1970 SWB Build |
Thanks for the replies.. Exactly what I'm need to know. I have already totally rebuilt my front end so... ball joints, tie rods, etc.. are all done. Sounds like the C-Notch is a "better to do it now" kind of thing than to realize afterwards you wish you would have.. Where do you all buy your Cnotches from?
The first picture is mine without a notch. The is no original bumpstop in there, but you can see where if there were you wouldnt get much travel before hitting it. I never drove it like this so I am only speculating.
The second pic is mine after the notch was put in. EDIT: Notch was from CPP about $100 Very well made also
1970 SWB Build |
thanks Jonathan.. $100 isn't bad.. for some reason I was thinking they were way more than that...
#7 | |
1970 SWB Build |
1970 SWB Build |
Thank ya sir... Although I think I'm going to shoot for the HD version... I'm probably going to want to tow a small camper or boat with the truck someday. They're 179 on the CPP site and I've emailed Jeff to see about a forum member discount that I seen some talking about. They're 199 free shipping on EBAY looks like. hopefully Jeff can beat that.
I have that kit on my truck. (w/18's) The ride is pretty dam good.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
Did you do the CNotch on yours?
#13 |
No C-notch and no issues. And we have some sh*tty roads here in CA.
#14 | |
///Relaxed Atmosphere
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#15 | |
hahaha... Thanks! We have a few here in MO as well. |
#16 |
Oh nice, thank you VERY much for the heads up on that... Definitely every little bit helps.
#17 |
C-10 Club Member
great kit....
Parts fit as advertised... Quality is outstanding.... Ride quality is good considering I have a 4.5/6.5 drop. I will eventually need to add a notch to avoid hitting the frame on big bumps.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#18 | |
I guess I should post up my tires and wheels. Does anybody see a problem with what I'm running with this kit? On the front is 17x8 with 4" bs wrapped up with 255/60's on the back is 17x9.5's with 5.5 bs wrapped up with 275/60's http://67-72chevytrucks.com/vboard/s...&postcount=109 |
#19 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I just counted and I have lowered six of my own trucks 4/6 with ECE parts since the year 2000.
The kits are fully complete. You will need a tub of wheel bearing grease for your bearings and a jar of brake fluid to refill the brakes. Every single other thing is included. All nuts, bolts, cotter pins, everything. I have never notched any of my trucks and won't be doing any in the future. I've hauled engines and lots of motorcycles without problem, even a Goldwing motorcycle. There are a few things in life that you can buy that give perfect service but they cost more than the competition. Danner boots, snapOn tools, and Early Classic Suspension parts. Buy the best and cry once. Read the review board before you buy any CPP stuff. We ought to rename that board the CPP complaint section. Posted via Mobile Device |
#20 |
![]() Join Date: Jul 2012
I used the 4/6 ECE kit as well. Simple install with very high quality parts. Everything was included....
#21 |
love it
#22 | ||
Still undecided on the c-notch, but sounds like I can get by just fine without one. Thank you all for the input. Really appreciate it. Posted via Mobile Device |
#23 |
RAT1968 '68 Cab/'71 Parts
Not that you need any more info.
ECE 4-6 here, too. Same as on my previous '72. Wouldn't do it any other way. Say "hello" to Stan and Mark for me (Bill Keener... they wouldn't know from "M17"). I haven't been down there for a while. 'Cause all the stuff that's on my truck that I bought from them (almost EVERYTHING ON THE TRUCK) is the best quality... .....and it all works.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#24 |
I have had ECE 4/6 on two of my trucks and it is the best complete kits for static drops.. But had to go with Porterbuilt when 4/6 wasn't low enough!
#25 | ||
Are you running a c notch? Posted via Mobile Device |
