04-16-2013, 12:36 PM | #1 |
Adding an aftermarket tach.
Being that my truck didn't come with a tach, does it still have all the hardware? Is it just a case of wiring the gauge up or is it something more involved?
Forgive me if this has been asked to death, I tried searching and didn't find anything.
1982 GMC C1500 4x4 w/ 305 and sm465. 2002 Kawasaki Ninja 250. 2007 Dodge Nitro. |
04-16-2013, 01:56 PM | #2 |
Re: Adding an aftermarket tach.
I wish I had made an install write up on this all you do is wire it up, what you need to do is just depending on what kind of fuse block you have whether it's the old school with the bulbs or more like the modern with small fuses, find out which fuses turn off when the truck is off and which one is on while the truck is on. and you'll have 1 wire that's green you'll need to run that to your distributor and then make sure for your ground you just find something that's out of the way of your feet, and then there you go!
I hope it all makes sense, if not I'll try to answer it better.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
04-16-2013, 02:33 PM | #3 |
I get it. Thanks!
I was really hoping it was going to be easy but I didn't want to buy the tach and then find that I was wrong. So many parts to buy, can't afford to waste time, money, and work on pointless endeavors.
04-16-2013, 02:37 PM | #4 |
78K & 79C Jimmys
i removed the aftermarket one PO installed ,
I used a hitch wire for ease of removal when using the aftermarket i added it to ign spot when i installed the cluster one i added it to the cluster feed
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-16-2013, 02:44 PM | #5 |
Yeah you can buy the tach and you'll just have to take a little bit of time out of your day to get it all put in, it took me about 30minutes to 1 hour to get all mine done.
