Door seal question
Does the cab to door seal clip on or glue on? Mine is mostly gone.
Re: Door seal question
Glued on
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
glue on for sure. I saw a company selling door seals that "just drill and snap in place" Yikes, that would scare me.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Glue on...and they are a mess to glue on...
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
If you use 3M weatherstripping adhesive, you need to lightly coat both parts, let them sit for a few to get tacky, then press them together. I found out that those $0.10 each acid brushes from a hardware store work pretty well. Use one for a few minutes, then chuck it and grab a new one.
Also, Keep some lacquer thinner handy, in case you get strings. Good Luck! Jeff
Thanks for the quick replies folks. Well the weather is getting warmer so i can leave the doors open while I work. Don't like sniffing glue half as much as i used to!http://67-72chevytrucks.com/vboard/i.../firedevil.gif
Jeff,
do you let the parts skim until dry and then fit together?
par4tom,
I let them sit for a few minutes until tacky. If it's good and warm outside, it could be less than 5 minutes. I'd do about 6 inches or so at a time until you get the hang of it.
That's a good idea!!!
FYI... Learn from my experience!
Use some painters tape and dry fit your seals!!! If your cab is not clean around the doors, clean it before you try to use tape! Take your time and tape the seal in place. Then test your doors! Open and shut them, see if you can adjust your strikers and hinges to get your doors to shut! Be warned!!!!!!! Not all seals that are sold to fit our trucks....fit! I bought 3 different kinds tested them all and ended up with the set from LMC that fit the best! I am not saying LMC is the best ones but they fit my truck the best. If you glue your first set in and have drama with them, now you have glue everywhere and you have to pull the seals off!! TEST FIT, OPEN and SHUT the doors before you use glue! Good luck! Posted via Mobile Device
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
We bought a set from LMC or somewhere like that and one door wouln't even shut. I searched this quite a bit on here and it is not a uncommon problem. We ended up chunking them and bought a set from Soff Seal and worked like a charm. Not saying you would have the same issue but I think we got a better product.
I have heard good stuff about Steele Rubber products.
#13 |
I used soft seal, took my time and installed 6 inches at a time, let it set over night taped up, then removed the tape and when closing doors ensured the seal was correct all the way around, left doors closed in the garage for two days, the seal will take a set, even now the doors have a tight seal and this has been 20 years later, the only problen arises at the kick panel and my big feet have the seal worn away from getting in and out...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#14 |
One of the 3 sets I bought came from soft seal, they would not work for me!
Just test fit and be sure before you glue them in!! Posted via Mobile Device
#15 |
The test fit is a really good idea, thanks for the info!
