Old 04-16-2013, 01:53 PM   #1
MisterC
MisterC's Avatar
Sending unit grounding point
Hey all,
I'm trying to get my interior all planned out and finished. In the attached picture, (Thanks Farmer66) the back of the cab has a detent where the the sending unit ground wire goes. I've seen this before, but mine doesn't have that. Which way is most common and why the difference?
Mine simply screws the back of the cab. The problem I have is that the screw pushes against the back of the center section of my buddy seats and I'm afraid it will eventually tear the fabric. I'm thinking I should just drill a hole in the sheet metal under the window and tuck it back in there.
Any opinions are welcome!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 04-16-2013, 03:09 PM   #2
WhippinSaw
WhippinSaw's Avatar
Re: Sending unit grounding point
You could use a smaller wire and a smaller phillips screw with a low profile to attach it. My 63 just screws on the back cab below window like that with no indent like yours. With those nice seats it probably would be better to move it.
WhippinSaw is offline   Reply With Quote
Old 04-16-2013, 03:11 PM   #3
Sharps40
Maybe put a button over it w/RTV. One of the original cigar lighter delete buttons from the dash would match up the interior. Or some creatively crafted cover in matching upholstery, etc. A polished stainless buttin head allen screw has fewer sharp edges and might look good. Move it to the floor behind the tank?? Etc.
Sharps40 is offline   Reply With Quote
Old 04-16-2013, 07:24 PM   #4
luvbowties
luvbowties's Avatar
Wink Re: Sending unit grounding point
Originally Posted by MisterC View Post
Hey all,
Pls. forgive this hijack of thread...but those buddy seats are some more nice, really as pretty as I recall seeing.
BTW: I like the idea of an ultra-thin-headed screw, without washer. I've seen some place on out trucks that uses such screws, maybe on the door around glass-channel? Maybe holding rear-of-hood insulation?
Keep up the good work. I'd buy your finished product w/o worry re: pre-thought applied and finished quality of work!
Sam
*After further thought, obviously you do not mind a bit of time to reach that extra degree of perfection: won't take that long to loosen/lean tank forward to also move screw to a really out-of-way position.
luvbowties is offline   Reply With Quote
Old 04-16-2013, 10:26 PM   #5
MisterC
MisterC's Avatar
Thanks for the ideas, all. FYI, those seats belong to 66farmer. I just used his picture to show the detent. Mine are black vinyl and houndstooth.
Old 04-17-2013, 05:14 AM   #6
Sharps40
I was rootin thru the toolbox last evening and saw another idea...the wire boot off of the back of an alternator.
