Old 04-16-2013, 03:38 PM   #1
par4tom
Door seal installation
Hey guys,
I was reading another post from a fellow 60-66 reader about door weatherstipping.
I just tore mine out because the previous owner made a complete mess trying to install them. Adhesive was all over the place.
What's the best way to put these on? I was thinking of running a bead deep in the stripping, then sliding them on and holding them on with 2" tape until the adhesive sets up.
Anyone have a better way? I'm going to be painting the entire cab and jambs in the next couple of weeks and want to minimize any messes I can!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 04-16-2013, 05:52 PM   #2
billd5string
billd5string's Avatar
Re: Door seal installation
That's exactly what I did with mine, I think getting a quality adhesive was the key though. I used 3M weatherstrip adhesive on mine.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 04-16-2013, 05:56 PM   #3
gofastnut
gofastnut's Avatar
If you use 3M weatherstripping adhesive, you need to lightly coat both parts, let them sit for a few to get tacky, then press them together. I found out that those $0.10 each acid brushes from a hardware store work pretty well. Use one for a few minutes, then chuck it and grab a new one.
Also, Keep some lacquer thinner handy, in case you get strings.
Good Luck!
Jeff
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-16-2013, 07:37 PM   #4
luvbowties
luvbowties's Avatar
Exclamation Re: Door seal installation
Good Luck!
Jeff
This method is likely best for sure bond. A drawback may be that once it touches, be sure it is in exactly the correct position, as you don't get many second chances, if any.
Having so many thumbs on my hands, I need to use the earlier technique to enable adjustable-shifting after making initial contact with the 2 surfaces. BTW: This method--"running a bead deep in the stripping, then sliding them on and holding them on with 2" tape until the adhesive sets up"--works long-term also!
Sam
luvbowties is offline   Reply With Quote
Old 04-16-2013, 07:56 PM   #5
gofastnut
gofastnut's Avatar
Thanks luvbowties,
That's a very important note I forgot to mention.
Jeff
C-10 Club
Old 04-16-2013, 08:57 PM   #6
theastronaut
theastronaut's Avatar
Use a scuff pad on the flange to make sure the glue has a good surface to bite into since you'll have fresh paint.
theastronaut is offline   Reply With Quote
