BIG CHEVY 3600 LONGBOX
Antenna Mount location - Template Lttle Help
I"m afraid the location of the hole is critical and the template tells me to, "position the template flush with the cowl line" and "flush with the mirror bracket" The trouble is, I have removed the mirror and filled the holes. If someone could give me a measurement I would appreciate it. Just remember, the only points of reference are the cowl line and the driver's side windshield wiper. 51 chevy
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
and a few others
Re: Antenna Mount location - Template Lttle Help
You posted this in the Pre-47 section, so I moved it for you.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Hi big chevy
I have a 52 gmc and the factory put a template up inside of cowl area so the mechanic had a very easy time drilling and placing the mirror and / or antenna on the truck if the customer wanted them after delivery peer up in the cowl area from emergency brake area (bend hunch contort away) hope that helped |
#4 | |
