BIG CHEVY 3600 LONGBOX
Need antenna mount location, template no help
I"m afraid the location of the hole is critical and the template tells me to,
"position the template flush with the cowl line" and "flush with the mirror bracket" The trouble is, I have removed the mirror and filled the holes. If someone could give me a measurement I would appreciate it. Just remember, the only points of reference are the cowl line and the driver's side windshield wiper. 51 chevy
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Re: Need antenna mount location, template no help
antennas are just plain ugly imo
mount it under the rocker panel mine works fine there ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#3 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=475162 |
I have it under the headliiner and have tried it in several places inside with no results. It's going to have to be mounted on the cowl. Also it's not a side mount antenna and even if it was It would be impossable to mount it there because my fuse box covers that area. My heater covers the right side so no
there.
#5 | |
Looked though the pictures and saw that i cut a hole on the inside wall to be able to get to the nut that bolts the antenna to the side of the cowl.. the top nut i was able to reach it by going over the top over the inside wall. covered up the hole with a plate and all was good..
http://67-72chevytrucks.com/vboard/s...d.php?t=475162 Last edited by parkwood; 04-16-2013 at 10:08 PM. |
Good looking Sub there.
thanks a lot, but it's not mine i'll built it for some friends in So. Calif.
