View Poll Results: What thread sealant do you use? | |||
Loctite 545 |
19 | 63.33% |
Teflon Tape |
6 | 20.00% |
Other |
5 | 16.67% |
Voters: 30. You may not vote on this poll |
Tot Roddin'
Fitting Sealant (Teflon Tape vs. Loctite)
What have you have the best luck with Teflon Tape, Loctite 545 or another thread sealant?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Tot Roddin'
Re: Fitting Sealant (Teflon Tape vs. Loctite)
I've used Teflon tape for various shop connections (air compressor line, attachments, etc.). Sometimes I have leaks sometimes I don't.
I've only used the Loctite 545 sealant a couple of times and I've had good luck with it as well.
Depends on application. I use teflon tape, thread locker, teflon paste, hi-tack, aviation, and rtv.
Tot Roddin'
Just thought it would be nice for those with leaks in their air ride systems.
Just a typical electric air ride setup. Posted via Mobile Device
![]() Join Date: Jan 2011
I use liquid/paste sealant, maybe not 545 but others (permatex) make it as well. I haven't tried tape for this application though it may do just fine.
I've used Loctite 545 on a few trucks and it has worked great for me. However, it's expensive.
///Relaxed Atmosphere |
For the air fittings loctite. But agree the price is insane.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Dec 2006
I used loctite 545 on mine, had some nasty leaks and it cured them.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
Hands down loctite 545. I agree the price is absurd.
Posted via Mobile Device |
I used Loctite 565, worked good, expensive too but a little tube goes a long way.
'71 GMC pickup; "Ashley," ![]() |
Always used teflon tape ,never had an issue.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
![]() Teflon tape doesn't seal, it works to condition the threads. It might seal, but that's not the job it was designed to do.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#13 |
Jimmydean is correct. Teflon tape is not meant to be used as a seal. Its so your threads don't grind together (steel on steel) when tightening your joint or connection. It act's as a lube.
#14 |
Used some Loctite 545 today to seal an oil line, but I usually use teflon tape. I was impressed with the job the 545 did though and will probably use it more often
#15 |
67-72 parts collector,…
![]() Join Date: Nov 2002
This,...
#16 |
White Seal pipe sealant with teflon.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer. |
#17 |
meowMEOWmeowMEOW
I just use the Napa branded "Liquid Tef". Apply a thin layer, let it tack up, screw together and your good to go. Did my last couple air-related projects that way, and I use it on all my air tools.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#18 |
![]() Join Date: May 2011
I will admit it, I am the 1 teflon tape vote, I am such a looser! I guess I better go to the store get some 545 so I can expand my collection of Loctite products.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
#19 |
C/10 junkie
Guess I'll be buying some 545
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#20 | |
#21 |
Fastenal sells it,...
#22 |
Go to any auto parts store and ask for it by name. They can get it for you. It is the recommended air fitting sealant for most manufactures. Mine was ordered from a NAPA I think.
#23 |
Tot Roddin'
Just have to say... Loctite 545 is a great product.
That is all. Posted via Mobile Device
#24 |
Man of Mini-Talents
My first go around I used Teflon tape, since the fittings already had it. Slow leaks. This last time I used 545 on the tape, and it rocks. It may be expensive, but I hate doing things twice.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#25 |
I work in a natural gas plant and teflon tape is what we use on just about everything. It seals great, and keeps threads from seizing up over the years. I work with anywhere from 800 - 1200 PSI. I reckon if it will seal that reliably, and for years on end, it will work with a 200 PSI air system.
The trick is getting it on correctly. Gotta wrap it tight and in the right direction.
'66 SWB BBW Custom cab factory A/C OEM roller 350/TH400 C-notched and bagged Frame off in progress! '69 Camaro Original 327 4 speed - completed |
