How to remove the yoke on a rear end?
I need to swap yokes from one rear end to another. The question I have is I have removed the bolt from both ends but neither of the yokes will slip off, do I just use a gear puller or is there another method so I do not have to purchase a gear puller.
Thanks in advance! Posted via Mobile Device |
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: How to remove the yoke on a rear end?
Also, the pinion bearings have a preload on them that is gone once you remove the pinion nut. The only way to set the preload is to remove the carrier and use a inch pound torque wrench or you can just do what most do and hammer the nut on with a 1/2 impact and call it good. The length of time before bearing and seal failure depend on the method used. |
Proprietor of Dale's Corner
Pics please the "removed the bolt from both ends" has me a bit confused about what you're asking
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Cluster King
Yes he is correct, the nut not the bolt.
Posted via Mobile Device What should I torque the nut to? |
Tap them off with a hammer TAP not beat the living sheet out of it, a little on each ear back and forth.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#7 | |
Cluster King
My advice is to find a reputable rear end shop and see if they can set it up for you. I know it seems like an easy swap but if it is not done correctly you will not have any idea what the preload on the pinion bearing is and shorten the life of them alot. You may or may not do ok just running the nut down with an impact until it does not have any play. There are youtube videos on setting up pinion bearing preloads. Watch one and you will understand more about what I am talking about. |
It looks like you got an answer, you should also change the crush sleeve to help with making sure preload is correct. The utube video will help you alot
#9 | |
![]() Quote:
Sam |
Alright all just wanted to say thanks!
Got the yoke removed and I used a harmonic balancer remover that I borrowed from the local parts store. Also all I replaced is just the seal at the yoke, I did not replace the crush sleeve. So far no leaks. Once again you all are awesome, thanks for sharing the knowledge to those of us green horns! |
