Old 06-21-2003, 06:18 PM   #1
kickboxr3
Unhappy alternater
Took my truck for a ride ,and the alternater wires melted down, right where the snap clip connects to it. A friend said it might be a bad Alt. another said bad coil. Any ideas?
kickboxr3 is offline   Reply With Quote
Old 06-21-2003, 06:19 PM   #2
kickboxr3
Alt
Oh yea, My truck is a C-10, 1971 Chevy
Old 06-21-2003, 06:28 PM   #3
jef5150
Inline 69
jef5150's Avatar
voltage regulator?? if you had a bad coil you probably be on the side of the road, did the truck DIE? what accessorys no longer work?,,,,,,your question is "kinda" general
jef5150 is offline   Reply With Quote
Old 06-21-2003, 07:29 PM   #4
kickboxr3
alternater
No the truck ran but the wires ran hot and melt down.
I was afraid of an electrical fire or something, on first inspection
the worst of it happened at the Alt plug in.
Old 06-21-2003, 07:44 PM   #5
jef5150
Inline 69
jef5150's Avatar
well ,you can test the alternator in the truck,,if you pull the pos+ cable off your battery while the motor is running and the motor dies your alternator is bad,,,,,ELIMINATE THAT POSSIBILITY FIRST
Old 06-21-2003, 07:46 PM   #6
jef5150
Inline 69
jef5150's Avatar
IM still thinking its a bad voltage regulator,
Old 06-21-2003, 09:11 PM   #7
kickboxr3
alternater
thanks, I'll try that in the morning when i get off work.
Old 06-22-2003, 11:14 AM   #8
ckenwright
ckenwright's Avatar
Take it to Autozone and let them test it for you for free. With a melting wire problem I wouldn't chance anything. Last thing you need is to loose your truck to a fire.
ckenwright is offline   Reply With Quote
Old 06-22-2003, 07:41 PM   #9
kickboxr3
Well guys i think i found the problem, I put a fresh 350 w/new style alt. I guess w/regulator built in it and i found the box wall
mounted reg. on the wall this afternoon. Guess one work against the other? I am learning the hard way now i guess but now that I
put this basket case together literally, I cant help but to love my truck.
Signed " NEWBIE on the block"
Old 06-22-2003, 08:16 PM   #10
jef5150
Inline 69
jef5150's Avatar
autozone????????you might as well take it to "K.F.C", or "BURGER KING" to have it tested,,,,,but thats my opinion,,,
Old 06-22-2003, 09:09 PM   #11
ckenwright
ckenwright's Avatar
If you're standing right there making sure the person is doing it right or know the person knows what they are doing, then you can get an accurate test. Still better than lighting your truck on fire trying to troubleshoot.
Old 06-22-2003, 10:19 PM   #12
kickboxr3
LMAO.......on KFC, Yeah you're right on the autozone test.......
It once cost me a 4 mile walk
