Old 04-16-2013, 08:24 PM   #1
Denee007
Denee007's Avatar
Speedometer cable question ;)
HI ya'll!
The question is, where would the speedometer cable come through the firewall? above the column or just to the passenger side of the column? The truck didn't have a speedo cable.
Thanks! dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-16-2013, 08:40 PM   #2
_Ogre
_Ogre's Avatar
Re: Speedometer cable question ;)
it went thru one of the many holes you welded up
mine goes thru the column hole as does my brake switch wire and oil pressure line
shop air compressor timer
Old 04-16-2013, 09:14 PM   #3
_Ogre
_Ogre's Avatar
you can see it goes thru the 4 hole grommet
Old 04-16-2013, 09:21 PM   #4
Denee007
Denee007's Avatar
That's a chevy truck? Just looks different. The four hole grommet is kind of difficult to make out in your excellent photo Is it just below the ridge that you convinced me in cutting off in my truck?
Old 04-16-2013, 10:35 PM   #5
OrrieG
OrrieG's Avatar
I ran mine up inside the cab against the firewall. Figure carpet pad and carpet will cover it. I will post a pic tomorrow.
OrrieG is offline   Reply With Quote
Old 04-16-2013, 11:13 PM   #6
1project2many
Right about here...
1project2many is offline   Reply With Quote
Old 04-17-2013, 12:27 AM   #7
G&R's57GMC
G&R's57GMC's Avatar
Yep right about there
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 04-17-2013, 10:28 AM   #8
Speedbumpauto
Speedbumpauto's Avatar
You can get those cables in different lengths. Get a longer one and route it yourself in an inconspicuous location. IMO, you don't want that ugly cable coming up there and ruining your firewall. I opted out for electronic speedo when I got gauges. Cost more but I don't have to worry about that problem.
Speedbumpauto is offline   Reply With Quote
Old 04-17-2013, 01:00 PM   #9
_Ogre
_Ogre's Avatar
great, now i get blamed for denee's fubars too
your firewall is sexy, admit it
yes, right where 1project2many showed where it use to be
Old 04-17-2013, 01:14 PM   #10
OrrieG
OrrieG's Avatar
Here is how I am routing my speedo and trans temp cables. It requires a small dimple where the trans cover meets the cab. I then ran them under the gas pedal and up the firewall. My insulation and carpet pad will be about 3/4" thick so they should not cause a carpet bulge. In this pic the temp cable has not been zip tied to the speedo cable. I used the 74 4WD extension to get the length I needed. With a standard trans you may not need it, on 4WD the speedo comes out of the back of the transfer case.
Old 04-17-2013, 01:16 PM   #11
OrrieG
OrrieG's Avatar
Wink Re: Speedometer cable question ;)
Yes and I am setting you up to take responsibility for mine too!
