04-16-2013, 09:46 PM | #1 |
Temp gauge problem
My temp gauge in my 70 when i crank to start the engine the gauge goes to full hot and stays there like it is stuck truck has new wiring & temp sensor ? Tryed a differant gauge same thing happened
04-16-2013, 10:02 PM | #2 |
Re: Temp gauge problem
It's wired wrong or grounding out I bet if new sensor and two diff gauges do the same thing.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
04-17-2013, 07:07 AM | #3 |
1969 Custom 30 wrecker
It's the resistor on the back. Or more likely, the insulators that go in that area. If I remember, they are just like washers that go on the posts.
Did you have it apart before this started happening?
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-17-2013, 12:00 PM | #4 |
There should be a resistor on the back of the gauge between the top and bottom posts. Picture is attached.
I should have a couple of extras if you happen to need one. |
04-17-2013, 04:53 PM | #5 |
is that one for a gauge or a light mine looks differant
04-17-2013, 05:36 PM | #6 |
That is the cluster with gauges.
71 K20 64 GMC mud truck |
04-17-2013, 07:58 PM | #7 |
here is the one I have I have 2 of them they are both the same and did the same thing
04-17-2013, 08:47 PM | #8 |
Different style, but same part.
Must be a sender, ground or other wiring issue. |
04-17-2013, 09:07 PM | #9 |
got it working !! whats the chances of having 2 bad resistors pulled a 3rd from a doner cluster and it works now thanks everyone for you help
04-17-2013, 09:41 PM | #10 |
Cool Truck
Could the resistor be the problem if the gauge always stays cold?
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
04-17-2013, 10:13 PM | #11 |
Glad you solved the problem!
