Headlight adjusters
Does anyone have a good picture of how the plastic headlight aim adjusters fit on a 63 grill?
I dont think mine are installed correctly or I have the wrong adjusters and springs to begin with... Thanks.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Headlight adjusters
All I`ve got so far.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
They just press into the grill.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
From the front or the rear? I tried to push in from the front and they pop right back out when there is any pressure applied.
Hmmmm...i"ll have to look when I get home, I want to say they come through from the back. When I polished my 63 aluminum grill I replaced all the springs/plastic parts, just cant remember which way the went in (front or back). If no one post between now and 7pm on it, I can let you know tonight. Are they new or old ones. I put in new parts and they were pretty tight. Also....make sure to have the correct year parts. I know there were some differences on some of the other years in design. 62-68 should be the same from what I see.
1963 C10,
thanks, i appreciate the info and the effort. I think the plastic pieces you posted are the ones I have but the springs don't look like the springs I saw on the classic parts website. Don't think they are available at a local parts stores either but if the springs are wrong, they may be placing too much pressure on the bucket and pulling the plastic inserts out of the holes. I will tear into this on the weekend and see what parts I have and what I need.
These are what the proper springs look like. Should be 1 per headlight. The long straight shank on the spring will slide into a groove in the headlight bucket. I can get pics tonight for you.
That would great! Really appreciate the assist on this.
Looking back at some pics, Im pretty sure they go in from the front. and sit flush w/the tab hanging out the backside. The spring will fit into the circular part that you see in the pic (just on the front, not the back) you can see the straight part of the spring sticking through. Ill double check on the plastic adjuster tabs tonight.
Maybe you`ll find something on here, actually not a bad video..several video`s
http://www.youtube.com/watch?NR=1&fe...&v=-aYO9ToUF_U
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
looked at my donar grill that i polished up. i took pics before disassembly and they were installed from the rear, which is the way i reassembled it. i counted the number of turns coming out to go back in, figured it'd give me a baseline at least until i installed and got to a shop to adjust properly.
dont know if this helps.. its on a 61 grill...
#13 |
Any one know of a source for the plastic pieces on 60-61 grill? Mine look like the one above, but plastic is stripped, not allowing adjustment.
#14 |
This is a little unorthodox, but i've used the license plate retaining plastic inserts to great success. I can take a picture here pretty soon and post it.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
#15 | |
![]() Quote:
Sam Here it is, by Towmater454: http://67-72chevytrucks.com/vboard/s...ight+adjusters |
#16 | |
![]() Quote:
![]() Sam |
#17 |
Thank you all for the replies - I'll get'er fixed now!
#18 | |
Senior Enthusiast
![]() http://www.classicparts.com/1958-61-.../#.VBCRm7l0x9A And this is the link to the screws: ![]() http://www.classicparts.com/1941-68-.../#.VBCSBrl0x9A They also carry the adjuster nuts for the 62-68 models: ![]() http://www.classicparts.com/1962-68-.../#.VBCSnLl0x9A
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
