04-17-2013, 07:09 AM | #1 |
First "long distance" boat tow
Took my 17' boat up from Hilton head to charleston this past weekend. Truck did great, but I was watching the heat hand the whole way. Two things kept running through my mind...1.) Is the transmission capable of overheating by towing in a lot of stop & go traffic and 2.) if I am going to do a lot of this, do I need heavy duty shocks as my back end was taking a beating going over all of the bridges?
Any insight by the much smarter members on this board would be appreciated. I am always impressed by the breadth of knowledge on here. Posted via Mobile Device |
04-17-2013, 09:06 AM | #2 |
the boat guy
Re: First "long distance" boat tow
I don't tow for distance, I tow for speed!
Mine sits on the bumpstops, bridges suck. A cnotch, bags and some good shocks might help. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
04-17-2013, 09:51 AM | #3 |
Active Member
Don't know what you have but to give you an idea I used to tow my tractor with bush hog and trailer (mostly highway) with my 69 with 350/350 and it handled it well. Farthest distance was around 80 miles one way and total weight was around 5500 lbs.
Truck is dismantled now but I had a 2 row radiator, no shroud, stock springs and IIRC medium heavy duty shocks. Never ran hot. For the buncing, you probably can't completely eliminate that except to go slower but another element to consider is tongue weight. Should be around 10-15% of total weight of boat and trailer.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
04-17-2013, 10:12 AM | #4 |
the biggest thing is to keep your trailer in excellent condition// grease bearings frequently.i always would carry a spare bearing set and have a spare tire for the trailer /plus makin sure you can remove the flat tire is good as trailer lugnuts are neglected alot an if you cant remove the flat well that is a problem
04-17-2013, 10:31 AM | #5 | |
Charlie Daniels w/ a Tq Wrench
Automatic trans? Install a bigger auxiliary transmission cooler, they are worth their weight in gold, yes stop and go will heat it up since it slips a lot at low speeds to get going, especially pulling a load. Plumb it inline after exiting the internal cooler in the radiator, then back to the transmission. As far as the rear, are you lowered at all? Helper bags, or even just replacing your coil springs in the rear with air bags is relatively simple and a great upgrade. You can soften the rear when doing normal driving, then stiffen it up when towing and level out any sag. If you are lowered more than 3-4" in the rear, I would suggest a bolt on c-notch to regain some suspension travel. You can weld or bolt on the c-notch, but the "bolt on" style typically adds strength back due to the extra plated material outside the normal framerails, whereas just a cut with a 1/2 tube or plate welded in weakens it significantly. Shocks could definitely help, avoid the "airshocks" they tend to leak down, and the shock side is usually poor quality, I like Bilstein shocks, they are very nice quality, tend to be on the stiffer side, but not too stiff, and feel really controlled.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
04-17-2013, 11:22 AM | #6 |
Thanks for all of the tips. I'm driving a stock 350 without a shroud and a 195 thermostat (which I replaced yesterday with a 180 degree one).
Just had the entire trailer redone. I was towing a 17' Center console with a 90hp motor. Tongue weight was probably ok. Thanks for the tips from everyone. |
04-17-2013, 12:00 PM | #7 | |
04-17-2013, 12:42 PM | #8 |
Nothing like damn near hitting your head on the roof while going over the bridge approach panel. Its a poor design and it seems like the panel right before and after the bridge always settles with time. Not fun to hit at 70 while pulling a trailer especially.
04-17-2013, 04:57 PM | #9 | |
I noticed when I was towing that, there were times when it seemed like I was getting pushed and pulled. No idea what this could have been from. |
04-17-2013, 05:17 PM | #10 | |
What do you all think about air shocks ? I know, it's kinda old school now but I could also weight help with my GMC because I use it hauling fire wood and they are much cheaper than air bags and I need to replace my shocks anyhow. |
04-17-2013, 05:33 PM | #11 | |
04-17-2013, 05:37 PM | #12 | |
How about telling us more like wheelbase, series, trans type and model. Maybe a SPID if is a stock truck. Trailer and tongue weight are good to know too. Be glad to give you all the factory towing specs I can based on your information. Are you just sitting running for half an hour? That will cause a spike in temp as everything heat soaks. Just turning into the wind or shutting the truck off are simple solutions. As far as being pushed around that sounds like your trailer. Wheelbase, spring type, rates and shocks can all affect that as well the trailer weight. But no matter a deadweight load like a boat is easier than a live load like horses. Had a pair of quarter horses that loved to sway side to side (in unison) going down the road. More so when we were stopped.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-18-2013, 08:21 AM | #13 |
If you are heating up from sitting, then your heat issue looks to be a result of poor airflow, first thing to check is your fan shroud, don't have one? GET/MAKE ONE! It is key to low speed cooling performance, check your fan clutch, if equipped, to make sure it is functioning properly.
The push/pull issue, was it side to side or forward/backward? A side to side issue points to low tongue weight, the motor and fuel tank being on the back of the boat can make this issue worse, try to load your gear in the front of the boat, to balance it out.
04-18-2013, 08:59 AM | #14 |
I'd be scared to Tow something like that
1971 GMC Sierra 1959 GMC 100 |
