Old 04-17-2013, 12:35 PM   #1
Alex V.
Alex V.'s Avatar
Rear Coil Spring ID
I picked up a set of rear coil springs from a guy I bought some other parts from, but as it turns out I won't be using them and might as well find somebody that needs them worse than I do. They've never been installed (repro) but I'm not sure exactly what their application is. They're variable-rate, the spring stock is .825" in dia., and they stand 13.0" high with no weight on them.
Assuming these are LMC, I see they sell VR springs in standard 1/2 ton, HD 1/2, and standard 3/4 ton ratings. Anyone know which application these are for?
Thanks in advance.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
